tranny wont go into reverse?help!!!
Old Apr 16, 2007 | 06:59 PM
ricanem1's Avatar
Default tranny wont go into reverse?help!!!
ok so i have a 2000 civic si that i just recently rebuilt for my turbo set up. anyways i couldn't find the clutch pilot tool so i just simply centered by hand and mounted the tranny. now my car won't go into reverse it seems to be like stuck. when i engage the clutch and try to put it in reverse it just grinds really bad and won't even budge? anyways do you guys think that it was cuz i didn't use the centering tool?or coudl it be sonething wrong with my throw out bearing? or the reverse on the tranny is gone?also it won't even go into reverse with the car off. your help is greatly appreciated!
Old Apr 16, 2007 | 07:00 PM
ricanem1's Avatar
Default Re: tranny wont go into reverse?help!!! (boricuaef9)
btw all the other gears are fine.
Old Apr 16, 2007 | 07:14 PM
sageuvagony's Avatar
DELETED BY MEEEE
Old Apr 16, 2007 | 07:22 PM
ricanem1's Avatar
Default Re: tranny wont go into reverse?help!!! (sageuvagony)
i need help not stupid comments.
Old Apr 16, 2007 | 07:24 PM
ricanem1's Avatar
does anyone have anything HELPFUL to say?
Old Apr 16, 2007 | 07:28 PM
lovey408's Avatar
id suggest u go back and fix wat u did differently.. a lot cheaper then just replacing the tranny
Old Apr 16, 2007 | 07:30 PM
ricanem1's Avatar
Default Re: tranny wont go into reverse?help!!! (lovey408)
yeah but do u have any idea what may be causing my car to not go into reverse? thanks.
Old Apr 17, 2007 | 05:35 PM
ricanem1's Avatar
does anyone else have any insight as far my problem?
Old Apr 17, 2007 | 07:07 PM
99TurboBlue's Avatar
I'm a Jackass cause i dont like to follow the rules.
no matter what you do it doesnt go in? sometimes you gottaput it in 4th, then swing it to reverse (i have to do that with my si). My buddy and I didnt use a centering tool when putting mine back togetehr and all the gears work perfect. If it was shifting before with no problems and you didnt touch the tranny, then I'm not 100% sure what it could be
Old Apr 17, 2007 | 07:09 PM
GetawayInMoscow's Avatar
Default Re: tranny wont go into reverse?help!!! (99TurboBlue)
If you got your tranny in, then you did a good enough job of centering it.
Old Apr 17, 2007 | 07:41 PM
JDM94HATCH's Avatar
Default Re: tranny wont go into reverse?help!!! (GetawayInMoscow)
some times i cant get into Reverse so what i do is go form 3rd to 4th then Reverse
Old Apr 17, 2007 | 07:43 PM
eklum's Avatar
i go 1st 2nd 3rd 4th 5th then reverse when i cant get it in. sometimes that doesnt work though.
haha
Old Apr 17, 2007 | 07:45 PM
95teilhatch's Avatar
check the fluid...it might be low. im not being a smart ***, im just making sure that you checked it before posting the question.
Old Apr 17, 2007 | 07:48 PM
JDM94HATCH's Avatar
Default Re: tranny wont go into reverse?help!!! (95teilhatch)
^^^ x2 haha
Old Apr 17, 2007 | 08:03 PM
Default Re: tranny wont go into reverse?help!!! (JDM94HATCH)
could be the problem huh?....
Old Apr 17, 2007 | 08:14 PM
BubblegumTate's Avatar
Put it in neutral, let the clutch out, then clutch in and shift quickly to reverse. It's a trucker's trick for shifting non-synchronized gearboxes. Letting the clutch out in neutral gets the mainshaft spinning the same speed as the input shaft, making it much easier to engage the gears.
I have to do that in my Si all the time, reverse is difficult to get into.
Old Apr 18, 2007 | 08:06 AM
Default Re: tranny wont go into reverse?help!!! (BubblegumTate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubblegumTate &raquo;</TD></TR><TR><TD CLASS="quote">Put it in neutral, let the clutch out, then clutch in and shift quickly to reverse. It's a trucker's trick for shifting non-synchronized gearboxes. Letting the clutch out in neutral gets the mainshaft spinning the same speed as the input shaft, making it much easier to engage the gears.
I have to do that in my Si all the time, reverse is difficult to get into.</TD></TR></TABLE>
double clutching into reverse y0
Old Apr 18, 2007 | 08:22 AM
instructor74's Avatar
Default Re: (EKlum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKlum &raquo;</TD></TR><TR><TD CLASS="quote">i go 1st 2nd 3rd 4th 5th then reverse when i cant get it in. sometimes that doesnt work though.
haha</TD></TR></TABLE>
Yeh like that is going to work. ever hear of a 5th gear lock out. Its not going to let him shift from 5th to reverse.( unless you have a 6 speed )
Old Apr 18, 2007 | 12:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">
double clutching into reverse y0</TD></TR></TABLE>
Yup. I just didn't want to say double-clutching, since usually it brings a flame-war about who knows what it means and who doesn't and generally involves quotes from The Fast and the Furious.
Old Apr 18, 2007 | 06:11 PM
JDM94HATCH's Avatar
http://g2ic.com/tegtips/driving/2.html
now u kno
Old Apr 18, 2007 | 07:43 PM
Well, I already did, but that's why I didn't mention the term.
Old Apr 18, 2007 | 07:47 PM
cycoclown's Avatar
I would reinstall WITH the clutch pilot tool. just a thought.
Old Apr 23, 2007 | 08:43 AM
ricanem1's Avatar
Default Re: tranny wont go into reverse?help!!! (cycoclown)
yeah i mean ive tried everything it just doesnt want to budge?i put new honda oem fluid and everything..?
Old Apr 26, 2007 | 08:14 AM
cycoclown's Avatar
=/ ... its the tranny so it couldnt be that many things. if anything here isnt helping, id go to a shop.
ek4si
Transmission & Drivetrain
Jun 13, 2012 06:45 AM
ftrms
Mar 5, 2009 06:23 AM
JDM3STAGEVTEC
Dec 23, 2008 12:10 PM
00civiccali
May 26, 2008 10:24 PM
SwIntegraB16
Jul 14, 2005 12:38 PM
