Question about 99-00 Y8 IM manifold and air injection
Old Apr 16, 2007 | 02:50 PM
JokerX-1.6T's Avatar
Default Question about 99-00 Y8 IM manifold and air injection
Exactly what does the air injection do thats so special on the 99-00 Y8 IM ? as it seems that everyone advertises thermal gaskets for 88-00 Y8 motors but in all reality they do not work right out of the packaging on 99-00 with out plugging up the holes. So what are the advantages to having air injection as opposed to not ? Has anyone else with a 99-00 EX plugged these holes up ?
Just trying to gather some info here.
Thanx
Old Apr 16, 2007 | 03:35 PM
EE_Chris's Avatar
Default Re: Question about 99-00 Y8 IM manifold and air injection (JokerX-1.6T)
It's like a FITV. Let's air pass when the coolant is cold and doesn't when it's hot. That's why it sits in the thermostat housing.
Old Apr 17, 2007 | 10:01 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerX-1.6T &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone else with a 99-00 EX plugged these holes up ?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">The holes here are 4mm. I needed to find the proper tap to thread this with, so I found this great wikipedia page here and there is no 4mm tap, but the 10-32 uses a #21 drill bit, which is 4.0386mm. So 10-32 it is.</TD></TR></TABLE>
Old Apr 17, 2007 | 09:54 PM
hondaZvic's Avatar
Default Re: Question about 99-00 Y8 IM manifold and air injection (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">It's like a FITV. Let's air pass when the coolant is cold and doesn't when it's hot. That's why it sits in the thermostat housing.</TD></TR></TABLE>
is that what this is??
Old Apr 17, 2007 | 09:55 PM
Luserkid's Avatar
Default Re: Question about 99-00 Y8 IM manifold and air injection (hondaZvic)
If it looks like the above pictures thats not the FITV thats the thermostat housing.
Old Apr 17, 2007 | 10:04 PM
hondaZvic's Avatar
Default Re: Question about 99-00 Y8 IM manifold and air injection (Luserkid)
would u happen to know what that broken thing is in the center? is it related to the "air injection" at all?
Old Apr 18, 2007 | 03:06 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">is that what this is??</TD></TR></TABLE>
Yep, more than likely. Part #24 is it.
Old Apr 18, 2007 | 03:31 AM
Ricey McRicerton's Avatar
Default Re: Question about 99-00 Y8 IM manifold and air injection (EE_Chris)
Mine are full of JB weld and have been for years. I installed a 99-00 y8 mani on a 97 y7 block probably 5 or 6 years ago and nobody seemed to have even heard of the air injection holes causing a problem at that point.
Old Apr 18, 2007 | 06:01 AM
Default Re: Question about 99-00 Y8 IM manifold and air injection (Ricey McRicerton)
yea going backwards is easy my question is what needs to be done to get rid of it while still using the 99-00 IM on y8 that has it as in what needs to be plugged and such.
Old Apr 18, 2007 | 07:01 AM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerX-1.6T &raquo;</TD></TR><TR><TD CLASS="quote">yea going backwards is easy my question is what needs to be done to get rid of it while still using the 99-00 IM on y8 that has it as in what needs to be plugged and such.
i would like to know this also....
mine is a stock 99 Y8, only im converting it to obd1. when u plug the holes on the mani, is there anything else u need to do? or is that it? or are there other parts that u can remove?
ill try to take some pix of mine tonight so maybe we can compare...
Old Apr 18, 2007 | 07:42 AM
yea im in the same boat converting to obd1 with a p28 - did you break the sensor in that pic ? I broke mine exactly in the same spot trying to get the hose off
Modified by JokerX-1.6T at 1:08 PM 4/18/2007
Old Apr 18, 2007 | 08:10 AM
hondaZvic's Avatar
Default Re: (JokerX-1.6T)
well.. that one i dont remember... this motor has been sitting for like 4 years... the hose that was on it, where did it run to?
but i did however break the Knock sensor off the back...
Old Apr 18, 2007 | 01:18 PM
from the helms manual
Old Apr 18, 2007 | 11:37 PM
hondaZvic's Avatar
i wonder if item #24 (the entire bolt/sensor) can simply be removed, and then just plug the hole on top of that thermostat with a bolt of some sort?
looking at the diagram above... i think if u put a plug on the intake, then remove the FIA control valve (#24) & plug it, then put a plug on the nipple on the manifold.. it might be ok...
especially if ur running obd1...
opinions??
Old Apr 19, 2007 | 12:08 AM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Mine are full of JB weld and have been for years. I installed a 99-00 y8 mani on a 97 y7 block probably 5 or 6 years ago and nobody seemed to have even heard of the air injection holes causing a problem at that point. </TD></TR></TABLE>
oh ya.. and i dont see any holes on the top of my mani...?..
Old Apr 19, 2007 | 02:32 AM
the holes he is talking about
Old Apr 19, 2007 | 08:34 AM
hondaZvic's Avatar
the holes he is talking about</TD></TR></TABLE>
oh, i see now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">i wonder if item #24 (the entire bolt/sensor) can simply be removed, and then just plug the hole on top of that thermostat with a bolt of some sort?
opinions?? </TD></TR></TABLE>
thoughts on this ^^ ?
Old Apr 19, 2007 | 01:47 PM
cmon I know someone here knows what to do
Old Mar 22, 2008 | 10:25 PM
AGENT 99's Avatar
HELP!
WHat ever happened with this? I have a 00 d16y8 that I need to use a 98 d16y8 intake manifold on. Do I need to plug anything or what??
Old Apr 9, 2008 | 10:00 AM
94CivicSi's Avatar
Bump. Would like to know as well.
Old May 14, 2008 | 12:18 PM
platinum00's Avatar
Default Re: (94CivicSi)
bump again...
I "think" you can plug the holes, port on top of manifold, and remove the FIA control value.
any verification to this?
-platinum
Old Nov 8, 2011 | 08:43 AM
95Sol99civic's Avatar
Only if u use the 99-00 intake. The only one with holes.
JDMRice
Apr 10, 2007 11:14 PM
igo4bmx
Jan 8, 2005 10:41 AM
EK k kay
Dec 13, 2004 07:54 PM
speedehatch
Dec 23, 2003 11:42 AM
