B18C1.. oem or cometic head gasket??
so im running a stock B18C1, all iv done is replaced piston rings, bearings, put arp head bolts and rod bolts in it... now i called Inlinefour.com and they asked how thick i would like the head gasket, since these are made custom... im running a T3/T4 (not sure of the name brand) turbo.... what i need to know, and i was told this would be the right forum to ask, is how thick should i get the head gasket.?? one gentleman on here told me to go .041" because it could bring it down to 9.1:10 compression ratio i believe is what he told me?? is that right, and is that what i want??
Thanks for the info guys!!
Since its a stock motor, i'm sure your not going to be running lots of boost. I'd say run a stock oem gasket again. You will make more power that way, and as long as its tuned conservatively you wont have to worry about detonating or any other problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supabang »</TD></TR><TR><TD CLASS="quote">lower compression = safer boosting
Low or high compression + good tune = safer boost
</TD></TR></TABLE>Low or high compression + good tune = safer boost
so... .070" would be just fine for this kind of setup then?? im looking to push about 15-17 psi.. lol.. my mechanic has being doing it on his stock b16 for 2 years now at 18 psi.. but like i said i cant get ahold of him
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Be sure you have adjustable cam gears and a competent tuner if you're going to run a thicker-than-stock headgasket.
no adjustable cams lol.. ****.. but i have an amazing tuner.. servion... sooo probably then.. .036? stock is .034 correct??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CO_HaTcH »</TD></TR><TR><TD CLASS="quote">no adjustable cams lol.. ****.. but i have an amazing tuner.. servion... sooo probably then.. .036? stock is .034 correct??</TD></TR></TABLE>
Talk to him about running a thicker headgasket without adjustable CAM GEARS (not cams) and let me know what he says to you.
ok i just hit him up.. it'll probably be a few hours, i dont think hes on h-t.. just high altititude imports.com... and im about to leave work.. so when i get home.. and ill let you know what he says.. thanks for the help!!!
Freshdot
Sep 20, 2010 10:41 AM
