cometic headgasket thickness
Old Jan 24, 2009 | 12:40 PM
keving85's Avatar
Default cometic headgasket thickness
b18b1
ok i am rebuilding my motor with just a stock rebuild and stock head...... i am going to have ARP head studs and i am just wonderin what the best thickness head gasket i should run..... the turbo setup is running on 8psi daily drivin.....
kev
Old Jan 24, 2009 | 12:54 PM
rota92
Guest
Posts: n/a
Default Re: cometic headgasket thickness
Was the head milled at all when it was off?
As you probably know, the thicker the HG the lower the compression. If you had the head touched at all it will raise the compression. It's really not that much of a deal, but if it wasn't touched grab a stock unit (or tell them you want the stock thickness) and call it a day.
Old Jan 24, 2009 | 09:00 PM
blinx9900's Avatar
b18b1 already is low enough compression, just go with an OEM thickness or what ever gasket you need to keep your OEM CR.
URNVS
Jun 17, 2006 07:44 AM
h22a193
Jul 9, 2005 07:53 AM
fastludeh22
Oct 16, 2003 10:45 PM
Kellindal
May 18, 2003 10:12 PM
boosted_dc2
Mar 10, 2003 07:26 PM
