using a 0bd2 harness for a 92 civic (h22 SWAP)
Old Apr 16, 2007 | 01:58 PM
marcusgnf's Avatar
Default using a 0bd2 harness for a 92 civic (h22 SWAP)
ok so right now im having alot of trouble locating a obd1 h22 harness for my swap
im just wondering if can use a harness off of a 2000 prelude, without it becoming a major headache to wire up for my car, keep in mind ill be using a 0bd1 dizzy, (aftermarket RC) injectors, and Modified P28 ecu
i also heard somewhere that it was possible to use a f22 harness, would this work? because i can get a hold of one of those for real cheap (the OBD2 vtec ad the OBD1 non-vtec harness's)
help is greatly appreciated thanks
Old Apr 16, 2007 | 04:08 PM
marcusgnf's Avatar
Default Re: using a 0bd2 harness for a 92 civic (marcusgnf)
bump
Old Apr 16, 2007 | 04:36 PM
97Ej6mike's Avatar
The OBD2 harness would work for everything except the dizzy, and to solve that would require some re-wiring. Theres a few write-ups in here on that.
Not totally sure on the F22 harness, but being that an H motor is the DOHC equivalent of the F motors, i wouldnt see why it wouldnt work at this moment, as long as its from the EX, so its wired for VTEC. I could be wrong, but it sounds logical to me.
Old Apr 16, 2007 | 06:45 PM
marcusgnf's Avatar
ok thanks for the answer on the obd2 harness, as far as the f22 harness goes i think ill just buy both and compare the two for ***** and giggles (f22 harness=5.00) and post my findings on the issue for people in the same predicament*? as i am
Old Apr 22, 2007 | 04:21 PM
H22 Swap's Avatar
yes u can use f22 wiring harness i just did a swap like yours its really easy to do
b18csedan
Apr 26, 2010 02:54 PM
honda_hackett
Nov 25, 2008 01:17 PM
jdmekrobot
Mar 13, 2008 12:13 AM
civichb97
Dec 9, 2002 01:22 PM
