will honda fit HFR rims fit on a gsr integra?
You can run them, but you need to run 10mm spacers since the offset is +55. With the 10mm offset, you'll end up with an ideal offset of +45. I recommend running extended studs too since you are spacing it out 10mm, which is a lot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TireRack.com »</TD></TR><TR><TD CLASS="quote">Offset
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
Zero Offset
Positive
Negative
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808jdm_profileEG6 »</TD></TR><TR><TD CLASS="quote">thanks for the info nick...just what I needed to know.do u think its even gonna look nice with those rims though?
They would look ok, but they weigh 17.75 lbs per rim.
