Can't Open The Airbox, am i screwed?
Old Apr 16, 2007 | 10:25 AM
EscaBoi's Avatar
Default Can't Open The Airbox, am i screwed?
ok so, i was down in the garage changing my headlights and i figured it was a while since i changed the air filter. i took out the screwdriver and it turns out the screws are locked, i can't turn them, most likely rusted, but i opened the airbox just 9 months ago when my friend changed the filter. maybe he might have tighten them super tight or i'm thinking it's rusted.
I used my racketing screwdriver and it just snapped the bit and broke it RIGHT OFF!!
am i screwed or what?? lol cause i can't open the airbox
Old Apr 16, 2007 | 10:31 AM
Manga_Spawn's Avatar
Soak the screws in wd-40 or something. That usually helps me when I have a subborn screw or bolt to get out. Other than that you may be screwed and have to drill them out or something. Good luck.
Old Apr 16, 2007 | 12:04 PM
t0p_sh0tta's Avatar
Default Re: (Manga_Spawn)
Umm.. can't you just use a 10mm socket?
Old Apr 16, 2007 | 12:08 PM
EG2Driver's Avatar
Default Re: (t0p_sh0tta)
if you replaced your filter 9 months ago, its still good unless you drive through fields and in dusty areas.
Old Apr 16, 2007 | 08:37 PM
EscaBoi's Avatar
well i tried using the socket, but it's stuck, it literally almost broke the airbox when i started trying to turn it pulling so hard.
the screws are holding the box in place right now, i'll try the WD40 suggestion by soaking it with a cloth or something
Frankie324
Honda Civic (2001 - 2005)
Mar 21, 2012 07:49 PM
Nihsnek
17
Dec 30, 2011 02:40 PM
Briman2021
22
Jul 20, 2003 08:36 AM
sicivic
Aug 8, 2002 05:14 PM
VTEConly
Jul 9, 2001 01:17 PM
