accord piston problems
i am rebuilding my accord and i have new JE forged pistons (which the warrenty is now up on) made for my car but for some reason they are such a tight fit it took a hammer just to get it started what can i do to make them fit i called machine shops about boreing it but they said you cant just bore it out a little bit it only to certain specs so any ideas about how to help me would be greatly appreciated
What make & year is your accord/engine? Do you know the diameter of the pistons that you bought, are they 85mm or 85.5mm+. That .5 can make a big difference in the fitting of your pistons.
FYI all of the F series engines are an 85mm bore with the exception of the F23A1-6 and A5 Euro. and an engine rebuilder should be able to bore/hone your cylinders to match a .5mm over piston very easily. If you talk to them and they say that they can't do it...call the next one down the list in the phone book
Modified by GhostAccord at 7:51 AM 4/18/2007
