Where to find this type of connector for JDM turn signals?
I'm looking for the harness connectors that fit into the turn signal sockets for the JDM headlights (shown above)
I can only think of 2 options (aside from just using generic female connectors directly on the pins):
1. pull some off of a jdm front clip
2. find another honda/acura vehicle that uses the same type of connector.
I have been looking through honda/acura parts catalogues online and so far, no luck.
Any help/suggestions?
I used some usdm turn signal lights and made them fit, I can't think of the bulb number. Just match it up to a similar bulb and you will have to modify the bulb plastic where it screws in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg97 »</TD></TR><TR><TD CLASS="quote">I used some usdm turn signal lights and made them fit, I can't think of the bulb number. Just match it up to a similar bulb and you will have to modify the bulb plastic where it screws in</TD></TR></TABLE>
sorry if my post was confusing...i dont need the actual BULB, i need the WIRING HARNESS connector that plugs into the piece shown in the picture
you should be able to modify a USDM one to fit into the turn signal houseing though. Or modify the housing to fit the US bulb holder.
I haven't seen that type of connector anywhere though.
I just did this literally a week ago. I used the USDM bumper turn signal socket, the only part that doesn't work is one of the tabs on the light socket is a little too wide. I just took a small file and filed the jdm headlight notch a little wider to accomodate it. Works fine, they were a little hard to install, but I'd rather them be tight and not leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvtec95 »</TD></TR><TR><TD CLASS="quote">I just did this literally a week ago. I used the USDM bumper turn signal socket, the only part that doesn't work is one of the tabs on the light socket is a little too wide. I just took a small file and filed the jdm headlight notch a little wider to accomodate it. Works fine, they were a little hard to install, but I'd rather them be tight and not leak.
thanks for the info...i might have to give that a shot
</TD></TR></TABLE>thanks for the info...i might have to give that a shot
