Rear wiper issues
Old Apr 15, 2007 | 09:02 PM
GloomyX's Avatar
Default Rear wiper issues
My rear wipers needs constant adjustment in different weathers... it's driving me nuts!!!
The bottom half of the wipe cycle (near the base) is normal, but once it gets to the top of the wipe cycle it doesn't wipe any top part of the hatch window.
I've changed the wiper already, and it doens't change a thing.
I can bend and arch the wiper arm even more to it puts more pressure against the hatch window, but it looks bad and really weird because it is looped up.
Can anyone help me out here?
Much appreciated!!
Old Apr 16, 2007 | 08:38 AM
97Ej6mike's Avatar
Sounds like you need to replace the actual wiper arm and assembly if thats what your getting at.
Old Apr 16, 2007 | 08:43 AM
WihaSi's Avatar
Default Re: Rear wiper issues (GloomyX)
Don't use the rear wiper? Mine is starting to do this too, doesn't bother me all that much though...wipes enough for me to see out of.
Old Apr 16, 2007 | 09:30 AM
waddy41's Avatar
i deleted mine...doesnt affect much...
Old Apr 16, 2007 | 11:19 AM
dad0c402's Avatar
I would say it's probably your spring that holds the arm against the glass. If that had gotten weakened even bending the arm wouldn't matter because the spring is what's putting force down not the arm.
Old Apr 16, 2007 | 10:59 PM
GloomyX's Avatar
so only solution is to replace the arm and the spring?
Old Apr 17, 2007 | 05:46 AM
charlie0801's Avatar
same thing happened to me with my old car, the spring holding the wiper to the window is losing its tension due to age, the only thing you can really do is either change the whole wiper assembly or try to find another spring that would hold that tension
jefe
Aug 31, 2004 12:48 PM
xcellorator
Jan 19, 2004 06:08 PM
