Wheel shake
I am baffled so I bit the bullet and I am going to ask a question.
I recently swapped out my si wheels for some circuit 8's on my 96 hatch. Now ever since I put the wheels on I have a vibration around 77+MPH. I have hub rings on them and I swapped out the stock lugs (I know that I am not supposed to run them) for some tuner lugs and the damn vibration is still there. I jacked up the car and checked for any play in the wheel bearings and there is none. The car has been recently aligned also. I am baffled.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 210EGhatch »</TD></TR><TR><TD CLASS="quote">tie rod ends</TD></TR></TABLE>
That is what I was thinking. When I pulled the wheel off I noticed the boot was done on the outer tie rod. On top of that the car has 207,xxx miles on it, so I guess after I lowered it, it was only a matter of time.
And all the lugs are the same, and the tires on fairly new.
Thanks
Thanks
