CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe
Old Apr 15, 2007 | 07:18 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe
So my hatches clutch is sliping I believe.
I noticed it today in 5th when I kinda punched it on the freeway and the rpms rose a good 150 and the car didnt really accelerate, didnt think much of it
Then later I tried to do a ripper from a stop light, shift into second was alright, not much of a pause between catching up to the motor. But then on the shift to 3rd it must of stayed there for atleast a second before the rpms came back down.
Im curious if adjusting the cable somehow can fix this?
Also because this is an older b16 I believe (obd0 pr3) cable trans, I dont know what version of the b16 clutch I can buy or if there all the same, or if the GSR clutches and such will work
Need some help
Old Apr 16, 2007 | 02:35 AM
PINKS's Avatar
Default Re: CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe (PINKS)
Old Apr 16, 2007 | 03:31 AM
stock99si's Avatar
i think my 99 si is the same, but im pretty sure my clutch is near the end of its life so prolly getting a stage 2 will fix that
Old Apr 16, 2007 | 06:47 AM
evilsolb16's Avatar
Default Re: CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe (stock99si)
you need to get one for a cable tranny the cluch disk is different than a hydro disk. get one from a 90-92 ls/gsr integra. and it should be fine
Old Apr 16, 2007 | 12:04 PM
PINKS's Avatar
Default Re: CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe (evilsolb16)
So as long as its for a cable tranny basically it will work
Old Apr 16, 2007 | 12:07 PM
evilsolb16's Avatar
yea
Old Apr 16, 2007 | 02:50 PM
W O T's Avatar
Arent 92+ b16's different?
Old Apr 16, 2007 | 06:08 PM
W O T's Avatar
Old Apr 17, 2007 | 02:40 AM
W O T's Avatar
Default Re: CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe (W O T)
Stage 3 on an n/a b16?
PINKS
Apr 18, 2007 02:36 AM
PINKS
Apr 16, 2007 12:07 PM
blackmagicCRX
Oct 25, 2004 11:59 AM
qwksi1
Feb 8, 2004 07:50 AM
