Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Experience with Using 10W-30 in 2002 Civic
Old Apr 15, 2007 | 05:52 PM
typeS's Avatar
Default Experience with Using 10W-30 in 2002 Civic
Hey Guys,
I'm normally over in the Prelude forum, but I changed my friends oil on his 2002 civic dx, 72,000 miles. The oil cap called for 5w-20, is it alright to use the 10w-30? All my friends use 10w-30 on their older civics. The car is driven in California, so it doesn't get too cold or too hot here. Should I change it again with something lighter? Please let me know, thanks.
Old Apr 15, 2007 | 06:58 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Experience with Using 10W-30 in 2002 Civic (typeS)
Use what oil the car calls for. There is no reason to use anything other unless you are using the car in severe duty conditions (turbo, towing, etc).
Old Apr 16, 2007 | 09:57 AM
djmota's Avatar
you should use the 5w20 its what the engine was designed for. 72,000 miles is not "old" for a civic. with the 10w30 there will be slightly worse gas milage and also a little bit more wear on startup than with the correct 5w20
Old Apr 16, 2007 | 11:30 AM
typeS's Avatar
So is it worth it to drain it out? Its my friend's new car and I don't want anything to be messed up on it.
Old Apr 16, 2007 | 01:45 PM
djmota's Avatar
I would. non synthetic oil is cheap. just drain and refill
dnoonkeste
Jun 28, 2011 10:47 PM
v0lcom27
22
Jul 13, 2005 07:30 AM
Evil_Wizard
52
Oct 28, 2002 09:05 AM
turrismaldon
Aug 31, 2002 09:37 AM
kidkutz
Jun 28, 2002 09:04 AM
