Will I have problems swaping a obd1 LS block into obd2 teg with ob2 v-tec head?
Old Apr 15, 2007 | 05:43 PM
luv2boost's Avatar
Default Will I have problems swaping a obd1 LS block into obd2 teg with ob2 v-tec head?
Will I have problems swaping a obd1 LS block into obd2 integra with ob2 v-tec head?
Any advise that could help me with the swap will help! THANKS!
Old Apr 15, 2007 | 05:54 PM
spun311's Avatar
Default Re: Will I have problems swaping a obd1 LS block into obd2 teg with ob2 v-tec head? (luv2boost)
Use the search button. You are going to need get the parts for a v-tec head swap. I have heard there is a lack of oil going to the head and you won't have the oil squirters to aid in cooling. This may sacrifice some longevity.
Old Apr 15, 2007 | 05:58 PM
luv2boost's Avatar
Default Re: Will I have problems swaping a obd1 LS block into obd2 teg with ob2 v-tec head? (spun311)
I have all the vtec conversion stuff. my question is for the compatibility of the ob1 block with the obd2 car and obd2 head.
Old Apr 15, 2007 | 06:23 PM
luv2boost's Avatar
ttt
Old Apr 15, 2007 | 06:29 PM
JDMBoostedDA's Avatar
im thinking you'll be fine. your head, intake and all that fun stuff has pretty much all the wiring on it. with that said, as long as your harness and the head are matching ECUs you'll be good. But who the hell am i to know?
Old Apr 15, 2007 | 06:49 PM
0260MOTORSPORTS's Avatar
It wors i had a 97 GSR with a b18c1 and i ran a P28 w/ chip and ran it OBD1 its cool there will just be less emmission sensors being used but leave them on for future SMOG..I had a guy do it for me and he removed everything i didnt need and when it came the SMOG i was done..It was a bitch to hook back up
Old Apr 15, 2007 | 06:51 PM
luv2boost's Avatar
Default Re: (0260MOTORSPORTS)
thanks man!
Old Apr 15, 2007 | 07:22 PM
luv2boost's Avatar
Default Re: (luv2boost)
any other opinions??
luv2boost
Apr 15, 2007 06:51 PM
Project_EK
May 25, 2006 06:48 PM
second edition
Jul 15, 2005 04:54 PM
