a/c question
Old Apr 15, 2007 | 04:55 PM
blackcrx16's Avatar
Default a/c question
if i dont get the a/c system vaccumed before i charge it with freon how will it affect the a/c system?
Old Apr 15, 2007 | 05:00 PM
t0p_sh0tta's Avatar
Default Re: a/c question (blackcrx16)
The system is vaccumed to remove whatever is in the lines and to confirm that there are no leaks.
Old Apr 15, 2007 | 05:18 PM
blackcrx16's Avatar
Default Re: a/c question (t0p_sh0tta)
if there are no leaks would not getting the system vaccumed cause the system to to cool as much or what?
Old Apr 15, 2007 | 05:25 PM
B18bEG6ick's Avatar
the more you vacuum, the more mositure you can get out of the system. which makes the better for cooling, but if you take something out; make sure you replace the disecant bag (reciever/accumilator). oh also once you put it into a vacuum, make sure it holds the vacuum for atleast 30 minutes (it think); so you know that it doesn't leak. good luck.
Old Apr 15, 2007 | 05:45 PM
t0p_sh0tta's Avatar
Default Re: a/c question (B18bEG6ick)
30min is correct.
JDM_Andrew
Sep 17, 2008 06:53 AM
Boostage
Jul 24, 2006 09:25 AM
forumnoobie
Mar 27, 2006 12:40 PM
