p08 vs p28
Old Apr 15, 2007 | 04:18 PM
l1bid0's Avatar
Default p08 vs p28
could both be used for z6? whats the difference between the two? i know p28 = z6 and p08= d15b.
Old Apr 15, 2007 | 04:22 PM
byronl's Avatar
Default Re: p08 vs p28 (l1bid0)
u wouldn't b able to pass smog with the p08
Old Apr 15, 2007 | 04:49 PM
JSPECSIR's Avatar
Default Re: p08 vs p28 (byronl)
p08 runs a 1 wire o2, p28 runs a 4 wire o2.
Old Apr 15, 2007 | 05:26 PM
skUnK2jdm's Avatar
Default Re: p08 vs p28 (JSPECSIR)
your better off with the p28
Old Apr 15, 2007 | 05:29 PM
mortificationrock's Avatar
Default Re: p08 vs p28 (skUnK2jdm)
Hey Really Im about to swap A JDM d15B wich would be best P28 0r P08
Old Apr 15, 2007 | 05:43 PM
THC07's Avatar
Default Re: p08 vs p28 (mortificationrock)
like said above the p08 uses a one wire. and the p28 uses a 4 wire.
the maps are almost the exact same, even with a 4 wire o2 and running a p08 your not gonna see any power loss or gain.
however, if you use the p08 with your d15b you will get better mpg
what i did was put the p08 base maps on a p30 base. chipped the ecu and used that. worked 100% and ran very good a/f ratio. for stock it was like 12.5 WOT
zenon8890
Dec 9, 2006 01:37 PM
dblock91
Feb 3, 2005 05:58 PM
1990hondaHF
11
Aug 21, 2003 09:29 AM
hYbRiD EeEkAy
Aug 16, 2003 10:51 PM
SprayinCX
Apr 12, 2003 08:45 AM
