Upcoming weekends CMP prep. 56k warning!
Old Apr 15, 2007 | 03:48 PM
Dave_B's Avatar
Default Upcoming weekends CMP prep. 56k warning!
Well had a few things to tie up from last DE. MSD wires had to go, VSS needed replacing and due to CMP's surface being much smoother than Sebring, I decided to lower the car another .5" Along with all that I had the tow hook to install and finally got my I/O port cam mount while I was at the 12 hour. Oil change and trans fluid flush are also in order, but won't happen until later this week. Along with the lowering job, I'm going to get the car aligned again and reset the camber again. -3 up front, and -1.5 our back.
Anyway... on to the pics. I have to say I'm pleased at the moment.
Parts necessary for day's work. Stock plug wires, VSS, I/O cam mount and tow hook.
Car going up on lift.
Under hood before work.
So last time I was out, first session I had issues with the speedo jumping and fluctuating. Also had Vtec engagement issues. Both signs of a bad/going VSS sensor. That day, I disconnected and reconnected the connector to the VSS about 5-6 times to ensure a solid connection. Never had anymore issues through the day except a few fluctuations of the spedo. I decided better safe than sorry and ordered one.
To get to the VSS sensor, remove the intake arm. Looking straight down, you will see a connector going straight down towards the left rear side of the trans. Disconnect this connector and with the removal of 2 10mm bolts, she's all yours.
This is the bad VSS still installed in the car.
Notice the green color on the center pin. Tell tale signs of corrosion.
This is what it looks like with the VSS removed.
This is the part you looking to remove.
If you do have corrosion on your VSS, this is what you want to use when you replace it on the connector side of the wiring harness. This will help remove/break up the corrosion on the connector.
Up she goes to get to the sussy. Remove all 4 wheels, on the PIC setup, you will loosen the bottom most tension ring, knowing how much you want to lower the car, you will move this "ring" up the threaded shaft. It's not to bad at all to do.
Front sussy with wheel removed.
Rear sussy with wheel removed.
This is the gap on the rear now. I ended up lightly rolling the "tab" that holds on the little rubber pieces. No rubbing at all.
Once the sussy was done, I lowered the car back down on the ground and checked the gaps, clearences and if I had achieved my .5" drop. No issues so far, but I'll bring the spanner wrenches with me just in case to CMP.
Next, I removed the front bumper so that I could install the tow hook.
Moogen intake horn...
Tow hook now installed.
Last up for now, the I/O camera mount. Finally I can review all of my mistakes.
I'll have a review once done this weekend. Hopefully I got it all right and don't end up rubbing somehwere.
Old Apr 15, 2007 | 04:03 PM
Hooch'n's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (Dave_B)
see you friday for some
Old Apr 15, 2007 | 04:09 PM
AssPenny's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (Hooch'n)
Nice... wish i could be there. Send me some pics.
Old Apr 15, 2007 | 04:10 PM
Dave_B's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Nice... wish i could be there. Send me some pics.</TD></TR></TABLE>
OMG, it's ButtPlug... Pshew Pshew Pshew..
I'll get ya some, hopefully Brad will get some good ones.
Old Apr 15, 2007 | 04:20 PM
Splat's Avatar
Collector-o-Guns and Drinker
Good stuff, Dave
You go with stock plug wires or what?
Old Apr 15, 2007 | 04:26 PM
Dave_B's Avatar
Default Re: (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">Good stuff, Dave
You go with stock plug wires or what?</TD></TR></TABLE>
Sure did, can't beat em.
Old Apr 15, 2007 | 04:37 PM
Doespike's Avatar
Awesome man! Bout time she hits the track again Here's to no mechanical/electrical/whatnot issues this time and more sweet pics
Old Apr 15, 2007 | 04:39 PM
chad's Avatar
Moderator
Default Re: Upcoming weekends CMP prep. 56k warning! (Doespike)
do i get a sesson in that beast?
Dave_B's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">do i get a sesson in that beast?</TD></TR></TABLE>
Trade for a session?
Old Apr 15, 2007 | 04:52 PM
Hooch'n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
Trade for a session? </TD></TR></TABLE>
i wouldn't do that.........
Old Apr 15, 2007 | 06:08 PM
paRRRker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n &raquo;</TD></TR><TR><TD CLASS="quote">
i wouldn't do that......... </TD></TR></TABLE>
haha. chad is all about trackin other people's cars
Old Apr 15, 2007 | 06:45 PM
Bradstard's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (paRRRker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paRRRker &raquo;</TD></TR><TR><TD CLASS="quote">
haha. chad is all about trackin other people's cars</TD></TR></TABLE>
Look who's talking
Old Apr 15, 2007 | 07:52 PM
get RIGHT's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (Bradstard)
Looking good as always, Dave.
We should really get him his own little spot up in the FAQ section with these write ups. .
Old Apr 15, 2007 | 09:05 PM
neo_'s Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (ITR 00-0477)
I had the same problem with my VSS plug.
Nice ricer sticker btw.
Old Apr 15, 2007 | 09:15 PM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Parts necessary for day's work. Stock plug wires, VSS, I/O cam mount and tow hook.</TD></TR></TABLE>
Your missing something on your list;
Have fun at CMP and post up some pics and vids.
Ali (who wishes he could of gone but has to take finals the week after the event )
Ali
Old Apr 15, 2007 | 10:54 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default Re: (Dave_B)
nice
Old Apr 16, 2007 | 04:27 AM
Dave_B's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">
Ali
Yeah yeah... If you can't install an emblem, just LMK and I'll walk ya through the process. I hope to come back with some pics. Depending on vid quality, and amount of on track mistakes... there might be a vid...
Old Apr 16, 2007 | 06:49 AM
Chris N's Avatar
sounds familiar
Old Apr 16, 2007 | 06:55 AM
Lifter2012's Avatar
looks good dave
Old Apr 16, 2007 | 07:55 AM
Euro98ITR's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (Lifter2012)
Great Dave
Old Apr 16, 2007 | 09:58 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Upcoming weekends CMP prep. 56k warning! (Euro98ITR)
looking nice Dave - that camera mount is super nice - I had the same one and the videos come out super nice
Old Apr 16, 2007 | 10:08 AM
paRRRker's Avatar
Default Re: Upcoming weekends CMP prep. 56k warning! (People_Mover)
now we all finally get to see dave put all this stuff into use
Old Apr 16, 2007 | 11:59 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by People_Mover &raquo;</TD></TR><TR><TD CLASS="quote">looking nice Dave - that camera mount is super nice - I had the same one and the videos come out super nice </TD></TR></TABLE>
I can't wait. Honestly, this is my fav mod at the moment due to the fact that it's very hard to really see/determine what you doing wrong while your doing it. Hopefully this will give me some insight and help me improve.
Old Apr 16, 2007 | 12:50 PM
I can't wait. Honestly, this is my fav mod at the moment due to the fact that it's very hard to really see/determine what you doing wrong while your doing it. Hopefully this will give me some insight and help me improve.</TD></TR></TABLE>
certainly makes you feel like a pro ricer, I mean driver
Old Apr 16, 2007 | 01:06 PM
mstewar's Avatar
aftermarket rear lca's?
have fun this weekend!
