Oil Pressure Build Up
Old Apr 15, 2007 | 02:29 PM
hotinteggy's Avatar
Default Oil Pressure Build Up
Ive searched for this topic and came up with one result, that had one reply. So the question is what is the best way to build up oil pressure in new engine before start up other than unhookin injectors and plug wire and turning the engine over? Thanks for the help.
Old Apr 15, 2007 | 02:31 PM
Th3savinday's Avatar
Default Re: Oil Pressure Build Up (hotinteggy)
ive heard you can unplug the ecu and turn it over? correct me if im wrong
Old Apr 15, 2007 | 02:42 PM
spoon_ek9's Avatar
why wouldnt u want to do it that way? just curious.
Old Apr 15, 2007 | 02:45 PM
hotinteggy's Avatar
Default Re: Oil Pressure Build Up (spoon_ek9)
Im worried about the pump losing prime and this taking all day.
Old Apr 15, 2007 | 03:08 PM
spoon_ek9's Avatar
in that case, just unplug the ecu and prime. fuel pump is controlled by the ecu, if ecu is not there, fuel pump wont pump
Old Apr 15, 2007 | 04:46 PM
CleanLikeJdm's Avatar
Hype-R Stalker
If you have enough assembly lube, I wouldn't worry about it as much,
But just unplug the ecu, crank it for a while, and then start it up.
Old Apr 17, 2007 | 06:04 AM
hotinteggy's Avatar
Default Re: Oil Pressure Build Up (CleanLikeJdm)
Thanks for the replies. I was worried cuz it has sat up after being built for a month or two.
beenba
Feb 3, 2018 07:56 AM
no_rice_please
Engine Management and Tuning
Oct 12, 2009 09:36 PM
b16a1sirhb
Apr 9, 2003 11:50 PM
