Throttle Bodies?
Old Apr 15, 2007 | 01:39 PM
watisjdm's Avatar
Default Throttle Bodies?
well i have an edlebrock intake manifold with my stock TB and i wanting to upgrade but keep it cheap and well i tried the b16 TB but doesnt work and i was told the LS TB will work!....can anyone vouch for that and if not that one which one would work?
Old Apr 15, 2007 | 01:59 PM
watisjdm's Avatar
Old Apr 15, 2007 | 02:02 PM
1995Civic's Avatar
If you want to stay with an OEM TB, then go with either the LS or GSR TB.
If you want to go aftermarket, pick up a BDL.
I personally like the GSR one (60mm i believe)
Old Apr 15, 2007 | 02:04 PM
Luserkid's Avatar
Default Re: (1995Civic)
The B16 TB should have fit, if it didnt then somethings wrong and the other B series wont fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">If you want to stay with an OEM TB, then go with either the LS or GSR TB.
I personally like the GSR one (60mm i believe)</TD></TR></TABLE>
watisjdm's Avatar
so pretty much the gsr and ls TB will fit my d-series tho?
Old Apr 15, 2007 | 02:06 PM
1995Civic's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">The B16 TB should have fit, if it didnt then somethings wrong and the other B series wont fit.
Speak of the devil....you can pick one up from this guy!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by watisjdm &raquo;</TD></TR><TR><TD CLASS="quote">so pretty much the gsr and ls TB will fit my d-series tho?</TD></TR></TABLE>
Yes, correct.
Old Apr 15, 2007 | 02:08 PM
watisjdm's Avatar
at the bottom the B16 TB was too long and cause a vaccum leak
Old Apr 15, 2007 | 02:41 PM
watisjdm's Avatar
would i have to mess with the TPS sensor ?
Old Apr 15, 2007 | 03:08 PM
Luserkid's Avatar
Default Re: (watisjdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">Speak of the devil....you can pick one up from this guy!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by watisjdm &raquo;</TD></TR><TR><TD CLASS="quote">at the bottom the B16 TB was too long and cause a vaccum leak </TD></TR></TABLE>
What throttle body gasket were you using? And no you dont need to mess with the TPS just use yours.
Old Apr 15, 2007 | 03:37 PM
pdiggitydogg's Avatar
if you use the gsr tb, you will have to swap your d series pulley over
(because the gsr pulley opens from a totally different angle than everything else)
Old Apr 15, 2007 | 03:45 PM
watisjdm's Avatar
b16 gasket
Old Apr 15, 2007 | 03:47 PM
watisjdm's Avatar
Default Re: (pdiggitydogg)
not to sound stupid lol what u mean pulley?
Old Apr 15, 2007 | 03:59 PM
(from EH3SiGRL)
Its the bronze-y wheel on the side - cable attaches to it
Old Apr 15, 2007 | 04:23 PM
watisjdm's Avatar
oh yeah gotcha.....thanks again man
Old Apr 15, 2007 | 05:03 PM
messeduprex's Avatar
send it out to maxbore i've heard nothing good abouthim and cheap as hell
Old Apr 15, 2007 | 05:29 PM
watisjdm's Avatar
Default Re: (messeduprex)
link?
Old Apr 15, 2007 | 06:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by watisjdm &raquo;</TD></TR><TR><TD CLASS="quote">link?</TD></TR></TABLE>
http://www.maxbore.com
Old Apr 15, 2007 | 07:06 PM
watisjdm's Avatar
thanks alot damn good prices
JDubya
Aug 22, 2013 01:38 PM
jdm97ek4
Dec 21, 2007 05:22 PM
LSegHatchy
Apr 1, 2005 07:07 AM
Steak84SS
Jun 13, 2004 02:26 PM
ITR1071
Jan 4, 2003 07:30 PM
