Auto Cluster w/ manual tranny
Old Apr 15, 2007 | 12:02 PM
WRXnomore's Avatar
Default Auto Cluster w/ manual tranny
Just swapped 5 speed into my 98 base (auto), I am using the auto gauge cluster and the D4 (Drive 4) light continues to flash. Can not find out how to disable. Any ideas? (w/ out buying a manual cluster)
Old Apr 15, 2007 | 12:57 PM
'95 BA8's Avatar
Default Re: Auto Cluster w/ manual tranny (WRXnomore)
New cluster? Or take the bulb out if it has one?
Old Apr 15, 2007 | 01:15 PM
El_Arsonista's Avatar
I'm assuming you swapped your ECU with a 5-speed one.
When it flashes, it's just crapping out because, obviously, the auto tranny (and D4 Gear) aren't there anymore. Just take out the bulb.
Old Apr 15, 2007 | 04:18 PM
syntax.'s Avatar
the little LED bulbs are a pain in the nut to get to without compleatly disassembling the cluster. On the 4th gens there is a seperate wire connection for the auto tranny indicator lights, you should be able to just unplug that connector.
Old Apr 15, 2007 | 04:20 PM
mafia's Avatar
Default Re: (syntax.)
Yes and if its a 5th Gen its a green plug.
Old Apr 15, 2007 | 06:39 PM
guitarlude26's Avatar
Default Re: (mafia)
Yeah man, i just did the same thing. JDM H22 swap and 5 speed conversionin my si, I'm just going to swap out the clusters when i get the cash. It sure is annoying though.
Old Apr 15, 2007 | 09:06 PM
JasonST's Avatar
Default Re: (guitarlude26)
How'd u manage to start ur car if it's hooked up in drive. For my car I had to hook it up to make it think it's in park or neutral or else it won't allow me to start the car.
Old Apr 16, 2007 | 08:54 AM
WRXnomore's Avatar
Default Re: (JasonST)
The disengauge switch was not wired up. I can start the car regaurdless of what gear it is in and regaurdless of if the clutch is depressed or not. I have to remember to always leave the car in neutral before starting or just make sure I push in the clutch before starting. Not a big deal..
Voodoo7
11
Mar 25, 2012 05:58 PM
MrRabbit87
Jun 22, 2009 11:39 PM
endlessdv
Apr 13, 2004 02:46 AM
xXx Justin xXx
Mar 27, 2003 08:04 PM
elmalouno
Nov 14, 2002 06:32 PM
