Head gasket removal
Hey everybody, I am fixing to remove the head gasket on a 94 civic 4dr stock...and im useing this DIY to help https://honda-tech.com/zerothread?id=1404941 . I would like to know which number the bolts are from this pic http://jdmlyfestyle.com/images/DSC040541.JPG (dual cams, mine are single). Is is 1,2,3,4,5 on the top or is it 1,3,5,7 on the top, beacuse the DIY says to remove in "you need to do this in the following sequence on the 12 mm bolts
1 7 9 5 3
4 6 10 8 2"
If you guys can help, thanks, and if you don't understand what i'm asking let me know.
Modified by mjsotelo91 at 1:27 PM 4/15/2007
1 7 9 5 3
4 6 10 8 2"
[intake]
9 3 1 5 7
8 6 2 4 10
[exhaust]
tq steps:
14ft/lbs -> 36 -> 49 -> recheck
its recommended that you do not reuse the headbolts - buy some arp studs that are reusable and will not stretch
the picture that youre referring to are for cam caps
the nubers i posted are for head bolts
9 3 1 5 7
8 6 2 4 10
[exhaust]
tq steps:
sohc doenst even look like that, so it would be pointless to number the picture
oh and for loosening, it is different:
2 8 10 6 4
3 5 9 7 1
camshaft cover removal sequence:
2 8 10 14 12 6 4
3 5 11 13 9 7 1
(reverse that for install)
I HIGHLY suggest you buy a GOOD manual before doing this.
There is a process to it...
2 8 10 6 4
3 5 9 7 1
2 8 10 14 12 6 4
3 5 11 13 9 7 1
this is a SOHC right? http://i19.photobucket.com/alb...8.jpg
(the pic is not my car by the way)
And the first number u said that it was different for removal..those are the head bolts u are talking about 1st right?....and will a Haynes manual cover it....im sorta new to the Honda thing so thanks for the help
JamesB1985
Mar 5, 2013 06:58 AM
streetlegal gocart
Aug 18, 2003 08:29 AM
