EF STD radio wires...help
Trying to install a deck into my sisters STD hatch but the previous owner cut the harness (pisses me off when people do this). I'm stuck with these wires that look to have been used on the previous owners setup so that's what I'm trying to work with. Can anyone identify these or tell me what wires I should look for?
I'm sure you could find this in a search, or even better at the12volt.com, but I will be nice and give you the benefit of the doubt. These wire colors are true of all Hondas/Acuras with some exceptions (like my 90 Si which had no rear speakers and so the front speaker colors were mixed with colors usually reserved for the rear).
red/yellow RR+
brown/white RR-
blue/yellow LR+
gray/white LR-
blue/green LF+
gray/black LF -
red/green RF+
brown/black RF-
red/black illumination
white/blue constant 12v
yellow/red accessory
black ground
brown/white antenna (doesn't apply to you)
You see the pattern with the speaker colors?
factory stereo wire colors OEM cut harness hardwire Honda Acura civic accord integra prelude
red/yellow RR+
brown/white RR-
blue/yellow LR+
gray/white LR-
blue/green LF+
gray/black LF -
red/green RF+
brown/black RF-
black ground
This is less work Hatch... http://www.installdr.com/Harnesses/HA-Wiring.pdf
94
94
