AC / Heater Problems (ANY HELP WOULD BE GREAT!!)
I have a 95 EX coupe, and my ac/ heat will only blow from the floor position, I've searched and havent found anything on this topic. I was wondering if one of you guys had run into this problem before. Thanks
Mike
Mike
trying changing out the selection console...the whole thing..
take off plastic around the cluster (two screws and one behide clock that you have to pull out with flat head), and your radio, and you should see a few screws. before you pull it out, gotta unlatch a small cable under the glove compartment.
the harness that gets unpluged (real pita to reach) from the switch is the likely prob.
luck
luck
methods555
Jul 22, 2007 08:26 AM
