Overpowering Sub with Kenwood Amp
I just bought
Infinity Reference 1030w
10" 4-ohm subwoofer
# recommended power range 50-250 watts RMS
# peak power handling 1,000 watts
# frequency response 25-400 Hz
# sensitivity 88 dB
Would this amp be okay?
Kenwood Mono Amplifier (KAC-8102D)
http://www.bestbuy.ca/catalog/...onics
I'm worried that the amp will over power the sub, I will not have my music blaring at 80% all the time, currently I listen to everything at 60% of max...
This is the deck I have... http://www.jvc.ca/en/consumer/...-G510
Thanks, Alot for all your help
John
10" 4-ohm subwoofer
# sensitivity 88 dB
John
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">A 300W amp on a 250W sub is not considered "overpowering".
Do you know what a gain **** is? (not meant to sound condescending)</TD></TR></TABLE>
Does that not control, the amount of voltage coming into the amp.. to the sub???
Some what like "Volume" Control..?
not precisely, but for layman's purposes, yes.. it tells the amplifier what signal it is receiving and ideally should be matched to the output signal from the deck, but for your purposes, just be conservative with them or you will get into clipping problems.. otherwise, you should be fine...
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
redteg1
Apr 9, 2002 08:46 PM
