rear brake change
Old Apr 14, 2007 | 11:41 PM
duyfash0's Avatar
Default rear brake change
Ok i have a 99 Civic hatch and it comes stock with rear drums.. On ebay they sell a complete set Front and Rear rotors for my car.. is there any modifications i need to do to replace the drums with rotors? Or anything else i need to buy to make it work?
Old Apr 14, 2007 | 11:43 PM
fmrprojects's Avatar
Default Re: rear brake change (duyfash0)
you need to get the whole rear disc brake conversion from an integra or civic si
Old Apr 15, 2007 | 12:15 AM
nighttrain33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">you need to get the whole rear disc brake conversion from an integra or civic si</TD></TR></TABLE>
Yeah. Most people (including myself) just get rear discs from a '99-00 Si or '94-01 Teg since it just bolts right up. And generally it's a lot less expensive than aftermarket rear disc conversions.
-Shane
Old Apr 15, 2007 | 09:52 AM
anfer's Avatar
u juss did this conversion to my 98 civic and it was pretty easy. u should get it from a SI so all the parts are more compatible. i advise u to change the prop valve as well
Old Apr 15, 2007 | 10:07 AM
adrenalinejunkie's Avatar
to make it work correctly you need to change the master cylinder, proportioning valve, and rear trailing arms
Old Apr 15, 2007 | 10:21 AM
BlueIntegraBoy's Avatar
Default Re: (anfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anfer &raquo;</TD></TR><TR><TD CLASS="quote">i advise u to change the prop valve as well</TD></TR></TABLE>
No, his hatch has the same prop valve as the Si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adrenalinejunkie &raquo;</TD></TR><TR><TD CLASS="quote">to make it work correctly you need to change the master cylinder, proportioning valve, and rear trailing arms</TD></TR></TABLE>
He doesn't need the change the master cylinder since he won't be pushing anymore fluid than the drums. Prop valve... see above.
Old Apr 15, 2007 | 10:43 AM
google-diy network rear brake conversion-i would take their word over little boy blue's
Old Apr 15, 2007 | 10:46 AM
tha_badguy's Avatar
why google when u just gotta search
theres a chart on here explaining the whole thing
& lil blue is right
Old Apr 15, 2007 | 11:22 AM
Default Re: rear brake change (adrenalinejunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adrenalinejunkie &raquo;</TD></TR><TR><TD CLASS="quote">google-diy network rear brake conversion-i would take their word over little boy blue's</TD></TR></TABLE>
How about I take the word on Honda's part number between the prop valves? And take the word on my own experience?
Old Apr 15, 2007 | 11:46 AM
anfer's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
No, his hatch has the same prop valve as the SI
ur right...i forgot bout that..i was thinkin bout my 98 lx which itz diff...lol
mynameizstitch
10
Dec 13, 2009 03:06 PM
MJobe
Jan 10, 2008 06:55 PM
mp5o
12
Jul 14, 2005 04:13 PM
jde_07
Jan 25, 2005 10:36 AM
