i need a new alternator.. performance.. for a stereo.. (99 civic si)
Old May 28, 2002 | 05:39 AM
funkylemons's Avatar
Default i need a new alternator.. performance.. for a stereo.. (99 civic si)
im plannin on runnin 2750 watts across 3 amps... I also need a better battery... do i need the alternator specific for my car? what shoud i look for.. i think the one i got now is starting to go and i dont even have my system fully installed (no amps yet)..its funny to hear tho.. when my hazards are on my engine pulses, like some alien engine.. its great.. so where do i look?
Old May 28, 2002 | 07:30 AM
EVIL Hx Coupe's Avatar
Default Re: i need a new alternator.. performance.. for a stereo.. (funkylemons)
The best thing to do is Rewound the one you have. They did it to mine like a year ago when I was into Car Audio and it was $150 dollars to make it put out 200Amps... for the battery get a Optima Yellow Top but I think you're gonna have to modify the thing to mount it cuz is wider then the civic battery......
Old May 28, 2002 | 08:37 PM
racecarpete's Avatar
Default Re: i need a new alternator.. performance.. for a stereo.. (Boost Pressure)
Rewound is the cheaper way to go, I am running an amptech alternator. You should run 2 batteries and if you do you will also need a battery isolator. Optima yellow tops fit under the hood with a little modification, I know cause i got one under mine
wtfisvtec??
Sep 14, 2012 04:52 PM
duyfash0
Dec 16, 2006 01:10 PM
hondapwr
10
Sep 11, 2005 01:07 PM
giooooo
Dec 10, 2002 09:08 AM
97excoupe
Feb 27, 2002 12:01 PM
