LS VTEC BUILD!!!!
getting my ls vtec build done soon, its a b18b block bored 30 over with wiseco pistions, balanced and micropolished crank and rods (stock ls), type r oil pump, block decked, b16 head (shaved) with skunk 2 stage 2 cams, skunk 2 dual valve springs, skunk 2 retainers, should make a little over 13:1 compression, 65mm throttle body, 4-1 header with 2.5 inch collector, test pipe, full exhaust, hopefully some injectors, and will be tuned with hondata... has anyone done something similar to this??? just curious on what kind of numbers ill get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c192DA »</TD></TR><TR><TD CLASS="quote">That will be sick... youll be puttin down 200</TD></TR></TABLE>
I would guess more.
I would guess more.
