Maybe the type r guru's can shed some light, ctr b16b throttle body size?
ive searched but found the civic forum said the ek9 tb was 60mm and the all motor forum said it was 62mm, does anybody in here know by chance?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godnf8 »</TD></TR><TR><TD CLASS="quote">60mm
All b16 tb's are 60mm except the 1st gen's which were 58mm</TD></TR></TABLE>
wrong info!!!
b16b has a 62 mm....
wrong info!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
wrong info!!!
b16b has a 62 mm....</TD></TR></TABLE>
wrong info!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">I've always thought it was 62mm.</TD></TR></TABLE>
I'm probably wrong, wouldn't be the first time
ctr motor has 60mm tb
itr motor has 62mm tb
end of story
i have a b16b please dont argue with me cause your gonna look really stupid if i post pics of my tb with calipers to measure it showing it is indeed 60mm.
end of story
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">ctr motor has 60mm tb
end of story
i have a b16b please dont argue with me cause your gonna look really stupid if i post pics of my tb with calipers to measure it showing it is indeed 60mm.</TD></TR></TABLE>
and if i put the calipers on the b16b tbody i have and it shows 62 mm who's gonna look stupid then??
I have installed 3 b16b's and all 3 had 62 mm tbody's on them.
end of story
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">pictures!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">I want pictures </TD></TR></TABLE>
ok. i wont be able to do this till waaay later, ill try and post around 10pm pacific.
Hey blinx, my ITR motor came with an "ITR" throttle body with a diameter of 60mm at the plate. Turns out it was/is a GSR throttle body. I had to modify it to run the ITR throttle cable. If I never told anyone you'd think the motor was originally set-up this way. FWIW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">Hey blinx, my ITR motor came with an "ITR" throttle body with a diameter of 60mm at the plate. Turns out it was/is a GSR throttle body. I had to modify it to run the ITR throttle cable. If I never told anyone you'd think the motor was originally set-up this way. FWIW.
i see your point, ill still post pics though, im also on a ctr forum, ill ask the guys over there to measure theres, some of them have owned the car since it was new.
</TD></TR></TABLE>i see your point, ill still post pics though, im also on a ctr forum, ill ask the guys over there to measure theres, some of them have owned the car since it was new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williejohnson »</TD></TR><TR><TD CLASS="quote"> http://asia.vtec.net/beystock/honda/civicr/
says 60mm</TD></TR></TABLE>
most of the major resources say 60mm, i dont understand why people think its 62, there confusing it with ITR. ill post pics later with mine, and others from ek9.org
ok, so i went and measured mine, and guess what? IM A TOTAL FUKING IDIOT
that ish was 62mm, sorry guys for posting wrong info, everybody who said 62mm pat yourself on the back
another day another lesson i guess.
62 would make the most sense since the CTR is just a destroked ITR motor. All the running gear is the same. IM/TB/tranny/exhaust manifold/cams can all be found on various ITR spec models.
A MAJORITY of honda enthusiastes still believe that B16b are just hyped up B16a's, when they are in fact less hyped up B18c's.
Glad you re-measured though to help clear the air.
3682 posts [100%]
Wilmington De
8-7-2002
« Re: Maybe the type r guru's can shed some light, ctr b16b throttle body size? (FullRaceHonda) « » 3:20 AM 4/17/2007 Reply Edit
less hyped up b18c with the same price as a C none the less both great motors in either form
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robfrmny21 »</TD></TR><TR><TD CLASS="quote">
Well, it's comparable in price to the GSR, but a few hundred cheaper than the ITR version. Personally, I'd probably take the B16b if given the option of the GSR or CTR, but I may be in the minority on that one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">ok, so i went and measured mine, and guess what? IM A TOTAL FUKING IDIOT
another day another lesson i guess.</TD></TR></TABLE>
Did you measure the inlet or outlet? I don't know if the thottle bodies have a tapered bore but that would explain the difference (62mm inlet/60mm outlet). Here's a pic of a stock b16a2 throttle body (62mm inlet) to add to the controversy:
another day another lesson i guess.</TD></TR></TABLE>Did you measure the inlet or outlet? I don't know if the thottle bodies have a tapered bore but that would explain the difference (62mm inlet/60mm outlet). Here's a pic of a stock b16a2 throttle body (62mm inlet) to add to the controversy:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullRaceHonda »</TD></TR><TR><TD CLASS="quote">OHH **** the plot thickens, how about somebody meaure the inlet diameter of the itr tb
ITR plate = 62mm.
GSR/B16 plate = 60 mm
</TD></TR></TABLE>ITR plate = 62mm.
