A/C not blowing cold any more. Causes???
Anyone have any idea's to why the A/C is blowing cold in my buddies 96 Accord. I don't know too much about A/C systems. Every honda i've own was the first thing that came out... Also the A/C is fully charged.
i've checked both fuese under dash and hood, seem to be fine. checked if fans come on when the a/c button is pushed nothing... now what?
are you sure it is NOT OVER CHARGED? if it is, it will not blow cold and the compressor will cycle on and off repeatidly
Guys did you read his reply. His fan didn't come on.
Check the fan first. But a jump test. get some cables and test the fan by jump testing it. Remove the connectors. Put one wire from the positive connection to the + battery and neg to neg. The fan should come on. If not replace the fan. If it doesn't come on, there is something wrong with the switch.
Also each time i was my car, I always clean the condenser. (front of the car) I just spray it with a sprayer and check there is no leaf blocking the condenser. Just a thought.
smsimon
Oct 23, 2007 06:45 AM
