rough/pulsing idle
Old Apr 14, 2007 | 12:20 PM
Cypher0117's Avatar
Default rough/pulsing idle
i have a few problems with my car but i think they are all related. I have a d15b7 engine w/ i/h/e. Lately my engine has been pulsing and shaking while idling. I can sometimes watch my shifter move back and fourth about 1/2inch to 1 inch. When it shakes like this, if i let off of the brakes it gets smoother but still rough. When driving i feel a lot of vibration in the shifter but don't noticeably see it move. Sometimes while the brakes are pressed i also hear a whistle that goes away once i let off the brakes. Lately the car also feels like it has no power until almost 3k rpm. Like its being bogged down really badly. I think this might be something to do with a vacuum leak somewhere, but can someone please verify this before i start spending money and replacing parts. Thanks in advance.
UPDATE
from further investigation and talking to people i think my car is running a little rich. My spark plugs are slightly fouled (dry sooty black stuff on them). There isn't any smoke that comes out of my exhaust that i know of but i do hear popping on occasion. Also i can sometimes smell gas from my exhaust after i turn off my car. From searching and reading i've concluded that it can be caused by, MAP sensor, iacv, bad thermoswitch/thermostate, leaky injectors, vacuum leak, weak ignition system, or dirty intake manifold. I don't think i have a vacuum leak, my manifold is clean as far as i can tell. The spark plugs are about 2 years old but i don't want to replace them until i find out what is really wrong. Can someone shed some light to help narrow some of this stuff down?
Modified by Cypher0117 at 7:33 AM 5/30/2007
Old Apr 14, 2007 | 04:43 PM
Cypher0117's Avatar
bump...anyone?
Old Apr 15, 2007 | 09:03 AM
Cypher0117's Avatar
no one has any ideas?
Old Apr 15, 2007 | 09:23 AM
BADHDRIVER's Avatar
Default Re: (Cypher0117)
@ idle where is the rpm
Old Apr 15, 2007 | 12:41 PM
veno's Avatar
Default Re: rough/pulsing idle (Cypher0117)
Did you find what was the problem ?
Modified by veno at 2:35 AM 4/16/2007
Old Apr 15, 2007 | 07:33 PM
Cypher0117's Avatar
Default Re: (BADHDRIVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADHDRIVER &raquo;</TD></TR><TR><TD CLASS="quote">@ idle where is the rpm
between 600 and 800 rpm
Old Apr 16, 2007 | 01:39 AM
veno's Avatar
I have the same problem. I also think it could be a vacuum leak problem. Have you checked all your hoses ?
Old Apr 26, 2007 | 08:38 AM
Cypher0117's Avatar
Default Re: rough/pulsing idle (veno)
sorry for the long break but i wasn't able to get to my car for a while. I did check all my hoses and i couldn't find anything noticeably wrong with them. What exactly am i looking for? One thing i did do while the car was running was disconnected the hose from the pcv valve on my engine. It started to shake a lot more for a few seconds and then the idle raised a little bit and it smoothed out. I drove it around for about 45 minutes and it was idling a lot better than it had been. I can still feel a lot of vibration in my shifter but i couldn't see the shifter actually move like i had been. My idle was around 800 the whole night. Is this a bad PCV valve? and why would that cause a rough idle?
Old May 30, 2007 | 09:11 AM
Cypher0117's Avatar
bump
Old May 30, 2007 | 12:40 PM
Cypher0117's Avatar
anyone?
Old May 30, 2007 | 03:01 PM
redcoats1976's Avatar
im not sure,but they are cheap and easy to change,so id try it first.my d16z6 has an off idle stumble between 700-1000 rpm only sometimes and only when hot.its got new plugs,wires,rotor,cap,pcv valve,and fuel filter.cant find any bad vacuum hoses and not showing any codes.gas mileage is normal WTF???
Old May 31, 2007 | 06:34 PM
Cypher0117's Avatar
Default Re: (redcoats1976)
i adjusted my valves this morning and it seems to be idling smoother. A lot smoother than before, but still not where i remember it. When i took my plugs out they looked like a mix between an overheated plug and normal. I ordered a new thermoswitch and thermostate to put in my car tomorrow to see if there is any effect. Anyone else have any ideas?
vincent_619
Nov 2, 2009 07:21 AM
Eighty-Nyne
12
Jun 13, 2009 11:45 PM
pvt_awol
Sep 15, 2007 09:35 AM
champLSinteg
Nov 1, 2006 02:24 AM
AMS_92EX
Mar 28, 2006 11:55 AM
