D15B motor throws codes for Barometric Sensor and Atmosphere sensors
Old Apr 14, 2007 | 08:46 AM
sony224422's Avatar
Default D15B motor throws codes for Barometric Sensor and Atmosphere sensors
I'm not a civic person, and I'm going to pick one up that needs a little work. The seller says he got a code for a TPS, replaced it, replaced the ECU and still didn't get it to start. Then he got the codes for Barometric Sensor and Atmosphere sensors and the car still won't start. What am i looking at to get it to start?
Old Apr 14, 2007 | 02:46 PM
sony224422's Avatar
Default Re: D15B motor throws codes for Barometric Sensor and Atmosphere sensors (sony224422)
anyone..
Old Apr 14, 2007 | 02:48 PM
komat's Avatar
i believe that has to do with the ecu
Old Apr 14, 2007 | 02:50 PM
sony224422's Avatar
Default Re: D15B motor throws codes for Barometric Sensor and Atmosphere sensors (komat)
i see. Should I have the seller try the old ECU and see what happens?
Old Apr 14, 2007 | 03:23 PM
sony224422's Avatar
im really curious cus i really need to figure out if its worth it for me.
Old Apr 14, 2007 | 03:26 PM
sicones's Avatar
the barometric sensor is inside the ECU
sony224422's Avatar
Default Re: D15B motor throws codes for Barometric Sensor and Atmosphere sensors (sicones)
so tech a new ECU should fix this
Old Apr 14, 2007 | 04:01 PM
sony224422's Avatar
and what ECU should i get. P05?
Old Apr 14, 2007 | 04:27 PM
sony224422's Avatar
anyone.
Old Apr 14, 2007 | 04:53 PM
komat's Avatar
i belive you can disable it within the ecu do a search on ht
Old Apr 14, 2007 | 06:42 PM
sony224422's Avatar
would those two things cause the car not to start? The cars an hour away so i don't want to get there and not be able to drive it away. so how would i disable it and make sure i can get it to start
Old Apr 14, 2007 | 09:25 PM
sony224422's Avatar
damn this forum moves fast.
what ecu or ecu's can i use in the car? Its a 93 CX with a d15b. i just need to get it started so i can move it off the lot.
Old Apr 15, 2007 | 01:41 PM
sony224422's Avatar
anyone
BIGef
Jul 31, 2013 03:52 AM
shytdoode
May 20, 2009 03:41 PM
v8killaz
Honda Civic (2001 - 2005)
13
Sep 11, 2008 03:33 PM
MaWeiTao
Apr 11, 2005 11:39 AM
kim_2_da_chee
May 30, 2003 06:18 PM
