is it a bad idea?
Old Apr 14, 2007 | 08:18 AM
magicguy's Avatar
Default is it a bad idea?
Im just wondering is it a really bad idea to run 95mm stroker in a B20/Vtec for street? the motor will be running 12.5 compression, motor will be running with skunk2 stage 2 cams?
Modified by magicguy at 9:35 AM 4/14/2007
Old Apr 14, 2007 | 08:29 AM
dbiker207's Avatar
Default Re: is it a bad idea? (magicguy)
i have no experience with this myself, but i have heard alot that longevity is an issue with such a large stroke. the large stroke sideloads the **** out of the piston which then scares the cylinder walls. hope this helps
Old Apr 14, 2007 | 02:45 PM
EF_LSVtec's Avatar
It doesn't really matter what you're running as long as it's tuned right...Only issue I see is the high cr using 91 octane..but again if it's tuned right then motor should last. YOu have to understand that if your motor is built right, everthing balanced, oil changed on time, no detonation issues, then it'll last for a long time...
Old Apr 14, 2007 | 03:52 PM
Dev15Bizz's Avatar
Default Re: is it a bad idea? (EF_LSVtec)
word
sh!ft
Apr 20, 2011 10:25 PM
a1320honda
Jun 23, 2009 11:15 AM
black99x
Aug 4, 2006 10:28 AM
. o 69 o .
Sep 10, 2003 09:54 AM
