Axle nut solutions!
Old Apr 14, 2007 | 08:10 AM
SLeePeR-STaTuS's Avatar
Default Axle nut solutions!
Alright the way I cracked them loose on my ek was by heating up the axle nut notch with a propane torch, then generously lubing it with some patented LIQUID WRENCH SUPER PENETRANT (I swear by this stuff), waited for like 5min (grabbed a brew), then used the standard breaker bar to crack it. I'm jus wondering whats the easiest solution for the home mechanic, and how your axle nut experiences went!
Old Apr 14, 2007 | 08:29 AM
pdiggitydogg's Avatar
breaker bar and a 4' length of steel pipe for more leverage
after you change them once, you dont need to worry about it sticking again
Old Apr 14, 2007 | 08:35 AM
Luserkid's Avatar
Default Re: (pdiggitydogg)
Air
Although if air doesnt do it i have my good friend Jimbo (30lb galvanized steel pipe) and he always gets the job done.... or atleast breaks my ratchets in the process
Old Apr 14, 2007 | 08:57 AM
EGhatch87's Avatar
air impact
Jay_Sensing's Avatar
I use my impact. I am yet to find on that she won't break loose
Old Apr 14, 2007 | 08:59 AM
buncha girls...
Old Apr 14, 2007 | 09:40 AM
92hatch_cx-t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">breaker bar and a 4' length of steel pipe for more leverage
I use the same thing it works real good or use an impact
Old Apr 14, 2007 | 11:05 AM
97Ej6mike's Avatar
I hire chuck norris to come over and simply stare down the axle nut until it just falls off.
Or PB-blaster, propane torch, and 4' breaker bar should do it.
Best way over anyhting.. Impact gun
Old Apr 14, 2007 | 11:11 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: (97Ej6mike)
impact
Old Apr 14, 2007 | 11:21 AM
messeduprex's Avatar
Default Re: (spork motorsports)
2ft long breaker bar than my 210 lbs. *** standing on the breaker bar works every time.
Old Apr 15, 2007 | 05:22 AM
burnitdown's Avatar
this little booger+5 ft pipe
Old Apr 15, 2007 | 05:42 AM
EG2Driver's Avatar
Default Re: (burnitdown)
stick a screwdriver in the rotor and push that against the caliper, it'll lock the axle.
Old Apr 15, 2007 | 06:35 AM
skUnK2jdm's Avatar
Default Re: (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">stick a screwdriver in the rotor and push that against the caliper, it'll lock the axle.</TD></TR></TABLE>
yea just put a screw driver in there and get a long breaker bar and a 32 mm and crack that **** loose!!
Old Apr 15, 2007 | 07:09 AM
Default Re: (skUnK2jdm)
you dont have to do that if you lossen them up with the wheels on and the car on the ground
Old Apr 15, 2007 | 07:17 AM
EG2Driver's Avatar
Default Re: (messeduprex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by messeduprex &raquo;</TD></TR><TR><TD CLASS="quote">
you dont have to do that if you lossen them up with the wheels on and the car on the ground </TD></TR></TABLE>
sometimes its really stuck in there good and the car will just rock forward or back. This way you don't put the transaxle under any stress, and i highly doubt you'll do any damage to the brakes.
Old Apr 15, 2007 | 07:45 AM
92ehatch's Avatar
i had someone hold the brakes, then i took a breaker bar with a 4' pipe on it.
and i jumped...and jumped, and jumped...fell and busted my shin....jumped some more, then it popped loose...and i fell and busted my shin again.
it was painful...but worked.
Old Apr 15, 2007 | 07:59 AM
nsxmatt's Avatar
I have a electric impact that has got off i'd say 20 or so axle nuts with no problems. Air is best if you have it.
Old May 15, 2007 | 11:17 AM
SOKDO's Avatar
Default Re: (nsxmatt)
I just replaced my passenger axle this morning but I wanted to tell my story.
1. tried my breaker bar which i've had forever and have done about 15 axles with with success but broke on this time around w/ 4ft leverage bar on my 96 hatch. ******* sprained my thumb to when i broke. Hard to use my thumb with my sidekick now.... Grrrrrr......
2. woke up this morning and tried my $500 craftsman compressor with my impact wrench. NO LUCK! Wasn't pushing enough ft/lbs i guess.
3, was gonna goto sears to buy another breaker bar and 6 sided 1-1/4 inch drive instead of the 16 sided one that came with my tool set but decided to goto my local tire store and they loosened it for me. first they tried there normal impact for tires but no go. then they tried a breaker bar that was twice as big as mine...no go... then he brought out this big MAMA impact gun. it loosened it. He did it for free but i gave them 4 bux that i had in my wallet for helping me.
This was the first time i had this much problems with an axle nut.
Old May 15, 2007 | 11:49 AM
boots420's Avatar
Default Re: Axle nut solutions! (SLeePeR-STaTuS)
cranking on it with an impact always does it for me...........
Old May 15, 2007 | 01:14 PM
Dipp-Set's Avatar
heating it up FTW... i always do that.. heated then some elbow grease.
butter99
21
Nov 27, 2008 09:00 PM
91-lsvtecsi
Suspension & Brakes
Oct 18, 2005 07:57 AM
gsrcivic619
10
Jan 5, 2004 04:07 PM
CimorelliCRX
Sep 13, 2002 11:34 AM
6.5inCivic
33
Aug 6, 2002 11:45 AM
