b18b in EK... BC Cams Stage 2 start up problem...
Old Apr 14, 2007 | 06:26 AM
chineseflyrice's Avatar
Default b18b in EK... BC Cams Stage 2 start up problem...
After I installed a new set of Brian Crower Stage 2 Cams and Valve springs, I tried to start the car and it keeps dying on me. It sounds like there is not enough fuel to it but i am not sure. I'm using the stock fuel pump and I thought it might be a air vacuum leak, so I changed the IACV valve, Throttle body and still no good. The only way I could get the car to fire right was to step on the gas a little bit and then fire it up and it works. Any ideas on fixing that problem? I don't want to keep stepping on the gas pedal to start the car up. Thanks! I ran a leak test, and compression test. Both test says it's normal..
Old Apr 14, 2007 | 06:28 AM
JDM-EJ698's Avatar
Default Re: b18b in EK... BC Cams Stage 2 start up problem... (chineseflyrice)
Are you getting spark?how is your timing?
Old Apr 14, 2007 | 06:36 AM
Default Re: b18b in EK... BC Cams Stage 2 start up problem... (JDM-EJ698)
Yea I am getting a spark, the timing on the cam is set at 0 degrees, i haven't changed them yet do you It could be the intake cam that needs to be adjusted?
Old Apr 14, 2007 | 06:37 AM
Luserkid's Avatar
Did you do a valve adjustment after you installed the springs?
Old Apr 14, 2007 | 06:43 AM
Default Re: b18b in EK... BC Cams Stage 2 start up problem... (Luserkid)
no, i don't think i did, the car runs fine after I step and hold on the gas pedal to fire it up . Could it be something with the air/fuel ratio?
Old Apr 14, 2007 | 06:47 AM
Luserkid's Avatar
Only if you have a wideband you wont know that. I would need to see (video) the car to actually know whats going on. If it sounds like its not getting fuel then you need a fuel pressure gauge to see if thats true.
Old Apr 14, 2007 | 06:54 AM
Jay_Sensing's Avatar
I would start with a valve adjustment. It's probably holding teh valves open slightly through the entire revolution causing you to bleed off a lot of compression.
diazeg92
Aug 29, 2011 10:05 PM
BoostedGSREJ1
47
Sep 13, 2009 08:55 AM
b20izzle
Apr 18, 2006 04:41 PM
xtegb16x
10
Feb 6, 2006 01:07 PM
