Which engine can be swapped to keep A/C?
I know some of you may say that if someone does a swap, they shouldn't worry about the a/c. But I want my car to have both form and function. I want to be able to keep my a/c and have a swap at the same time if that's possible. I've seen pictures up here that show that done, but I'm not sure which engine I can put in my eg. Which engines can be swapped into my car that will allow me to keep my a/c?
ANY bseries swap will allow you to keep ac.
Any H series swap will need some brackets fabed. I seen an h22 in a delsol and it had ac powersteering and nos
You can't have both with a h22 because it just won't fit.
well you need to get the correct mount. I know this is an issue with ek's (some people need to use the delsol ac bracket).
I dont know if it is an issue with EGs
thinkbrianthink bu
May 18, 2002 09:29 PM
