spoon balanced pistons vs. ctr pistons
deciding which to go with? I may need some help with this..
will the ctr pistons fit up with jdm gsr (b18c) rods in my 96 gsr motor?
will i need anything else besides pistons, rings, and pins?
also, which pistons would you choose?
thanks a bunch
thanks a bunch
Question is are the JDM GSR rods good w/ 12.5:1 Compression? What else are you upgrading?...I'm planning on pistons in the future, though w/ my mileage(90k), I'm probably going to go w/ the entire spoon balanced block.
jdm b18c rods are the same as usdm b18c5 rods....
not sure about 12.5:1 compr. with 91 octane pump gas.
been getting feedback & the verdict may be spoon itr pistons
how do u know that the jdm b18c1 gsr rods are the same as the US typer R rods b18c5? im just curious where or how u found this out, im not doubting you, but i have a jdm gsr motor and would like to know if this is true for sure
Remember! ! ! ! ! Name Brand doesn't always mean Power!
My advise, CTR Pistons, ITR Rods, light weight Flywheel. With that in a GSR, would be a beast, all you need now are some nice cams, if your on a Buget, I'd go with some CTR Cams, now your talking Beasty...............You will alo need a good header as well, I can vouch for the Spoon Header, make pretty good midrange power, let me know if your interested, $700obo
Good luck,
Nick
Good luck,
Nick
I have the Spoon/JDM ITR pistons in my engine and if I had to do it again, I would go with the CTR pistons. The Spoon pistons alone won't give you enought compression to give you good HP.
b18cda6
Sep 27, 2006 11:14 AM
tvrsir
Dec 7, 2003 10:39 AM
djickabod
Oct 26, 2003 12:07 PM
