Shift boot help
Old Apr 13, 2007 | 04:34 PM
gato5254's Avatar
Default Shift boot help
I installed a ctr the one with the red stitching in my hatch 96. NO Problems with the install. I wanted it to stay up, but it doesn't it looks limp not rock hard up. well i thought it was because my old boot didn't have that plastic ring, it didn't stay up. the new old has it but no luck it goes limp. some one know what to do or how to fix it. i was going to put a washer on the shifter but don't know if it will work when i get a different ****. i just want the boot to stay up any help?
Old Apr 13, 2007 | 04:42 PM
-JSpecEk*9-'s Avatar
Default Re: Shift boot help (gato5254)
get a short shifter. i got B&M and it holds up.
Old Apr 13, 2007 | 04:46 PM
gato5254's Avatar
Default Re: Shift boot help (-JSpecEk*9-)
really how does that short shifter hold it up??
Old Apr 13, 2007 | 04:52 PM
chansaephanh's Avatar
think what he meant was that with short shift its exact fit
Old Apr 13, 2007 | 04:57 PM
Default Re: (chansaephanh)
yes it does
Old Apr 13, 2007 | 05:09 PM
gato5254's Avatar
Default Re: (-JSpecEk*9-)
damn any other way really don't want to buy more things for my car. i think it has a short shifter already not sure but it's crome not black like my other civic 97
Old Apr 13, 2007 | 05:23 PM
Default Re: (gato5254)
post pics
Old Apr 13, 2007 | 05:49 PM
Padawan's Avatar
Darth ModerVader
It isn't supposed to stay up. It should leave some of the shifter exposed like this one (from an ITR):
Old Apr 13, 2007 | 06:02 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Shift boot help (Padawan)
What do you mean by "rock hard up"?
I don't think leather shift boots need to be hard at all. Sounds like you have some technical difficulties.
Maybe see an orthopod.
Kidding aside, yeah there should be probably 1"-2" between the boot top and the ****. I pushed mine all the way down so about 8" of the shifter is exposed. I think it looks neat and I can show off ym skunk2 bling.
Old Apr 13, 2007 | 06:21 PM
VTAC-KAT's Avatar
Default Re: Shift boot help (ek forever guy)
wrap some rubber bands under the ****. that will keep the boot where you want it
Old Apr 13, 2007 | 07:20 PM
gato5254's Avatar
Default Re: Shift boot help (EH2palmyblueSIR2)
but i want it not show the shifter don't think it looks right. check this one out https://honda-tech.com/zerothread?id=1935496. Thats what i want it to look like.
Old Apr 13, 2007 | 07:21 PM
gato5254's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean by "rock hard up"?
Kidding aside, yeah there should be probably 1"-2" between the boot top and the ****. I pushed mine all the way down so about 8" of the shifter is exposed. I think it looks neat and I can show off ym skunk2 bling.</TD></TR></TABLE>
by rock hard up i meant all the way up. like in that link.
Old Apr 13, 2007 | 07:30 PM
Jhonny Ricer's Avatar
as alkready posted use some rubber bands under the boot place the rubber band at the desired height you want the shift boot to sit at
Old Apr 14, 2007 | 07:17 AM
Silvertc's Avatar
Default Re: Shift boot help (Jhonny Ricer)
i would just leave it like Padawan said.
Old Apr 14, 2007 | 07:36 AM
TicToc A*moto's Avatar
Default Re: Shift boot help (jdmjr)
take some black electrical tape and wrap it around the shifter, wrap it around enough times to where the boot's hole can't slide over the tape, and there you have it. Ive been rocking mine that way for over a year
Old Apr 14, 2007 | 08:55 AM
MurdersV8s's Avatar
I had the same problem with my EH3. All I did was use a ziptie and put underneath the plastic ring on the boot. That will keep your boot up no problem.
Old Apr 14, 2007 | 12:23 PM
gato5254's Avatar
Default Re: Shift boot help (MurdersV8s)
thanks for the help guys i'm going to fix it monday
Old Apr 14, 2007 | 12:46 PM
cruizer's Avatar
Default Re: Shift boot help (TicToc A*moto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TicToc A*moto &raquo;</TD></TR><TR><TD CLASS="quote">take some black electrical tape and wrap it around the shifter, wrap it around enough times to where the boot's hole can't slide over the tape, and there you have it. Ive been rocking mine that way for over a year </TD></TR></TABLE>
thats what I did and it looks and works fine
Old Apr 14, 2007 | 12:55 PM
Eran's Avatar
HT White Ops
The way I do it, and it works PERFECTLY, is two neoprene washers from a hardware store. Take your entire shifter console off, put the neoprene washers on, and then replace your boot and console. Then start threading your shift ****, and slowly push your boot down as needed. It'll stay perfectly flush.
Old Apr 15, 2007 | 03:29 PM
gato5254's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">The way I do it, and it works PERFECTLY, is two neoprene washers from a hardware store. Take your entire shifter console off, put the neoprene washers on, and then replace your boot and console. Then start threading your shift ****, and slowly push your boot down as needed. It'll stay perfectly flush.
hey one more question how did you fit that ITR wheel in ur civic because i want to get one but every one it don't fit. i have a 96 hatch
Old Apr 15, 2007 | 03:33 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gato5254 &raquo;</TD></TR><TR><TD CLASS="quote">
hey one more question how did you fit that ITR wheel in ur civic because i want to get one but every one it don't fit. i have a 96 hatch</TD></TR></TABLE>
That's a steering wheel from an RSX Type S.
Old Apr 15, 2007 | 08:08 PM
Ek Forever y0!
Default Re: (Eran)
That's a steering wheel from an RSX Type S.</TD></TR></TABLE>
Yep. Looks good.
Old Apr 15, 2007 | 08:16 PM
gato5254's Avatar
Default Re: (ek forever guy)
Yep. Looks good. </TD></TR></TABLE>
stop following me
Old Apr 15, 2007 | 09:52 PM
ihatemyhonda!'s Avatar
i think it looks better natural. having it up is like your ******* having a boner its just not supposed to be that way.
Old Apr 15, 2007 | 10:02 PM
Eran's Avatar
HT White Ops
Default Re: (fuckingcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuckingcoupe &raquo;</TD></TR><TR><TD CLASS="quote">i think it looks better natural. having it up is like your ******* having a boner its just not supposed to be that way.</TD></TR></TABLE>
Worst post this week .... and it's the first day.
