clean my motor
i want to clean my motor because i bought my car used and the owner before me was a girl and i dont think she even changed the oil ever. when i change my oil like 5 min later i check the dip stick to make sure i had enough oil in it and when i looked at the dip stick the oil was jet black, it look like old oil. i want to give my motor an all around good cleaning, inside and out but i dont want to f up my engine. i was told to use a product called seafoam. do you think i should use it or not or is there something else i can use to clean the inside of it. here the link to seafoam.please help me
http://www.seafoamsales.com/motorTuneUpTechGas.htm
Modified by stinkypinky1011 at 5:42 PM 4/13/2007
i use simple green on my engine and clean up everything in the bay and use amor all wipes on the plastic parts to make it look nice and clean, my can be clean better, i only spent like 30 min on it..........
http://www.cardomain.com/ride/2349800
Try Z-max......It has (lynkite-(lean-kite)) in it.It is a molecule that works like oil, to lubricate the motors moving parts. The thing is lynkite is about 50 times smaller then an oil molecule, so it actually gets in side the micro cracks in metal and gives is a (wet)-very lubricated surface.when metal is lubricated that well it breaks down the bonds of carbon build up and gunk **** in the motor.I did a project with a lawn mower at school with it, and it got all the build up out of the motor, but it is not going to fix an extremely abused engine.If you mess up a motor long enough.......you proably just need a new one.
Peter Brady onlyonweekndz
Nov 26, 2007 12:55 AM
