honda accord problem
Old Apr 13, 2007 | 03:33 PM
87hondaaccorddx's Avatar
Default honda accord problem
I have an 87 honda accord DX and it is having a timing/running prob i cant figure out. When cold it idles at below 1000, and drives kinda ok, but sluggish/missing/no pwer. when it is warm most of the time will have a high idle around 3000 some times it will drop down to 1000-15000. from a stop when warm first has power but second acts like it gets too much fuel and bogs out, 3rd gets power and up. wile driving at times will miss/serge/ bog down and slow in speed. It seams to have goten worse cense i changed the plugs, wires, cap/rotor and fule filter
Can anybdy help??
raven99_jc on yahoo messenger
Old Apr 16, 2007 | 04:06 AM
slomob18b's Avatar
Default Re: honda accord problem (87hondaaccorddx)
Maybe u should check if the spark plugs were properly gapped. When you changed the plugs/wires did you do one at a time? I'm asking because maybe there is a chance that you put the wrong plug wires from the distributor into the wrong cylinders.
Double check it with this link:
http://autorepair.about.com/li...9.htm
sdmtkm
Feb 16, 2014 04:29 PM
startXtoday
Jan 4, 2012 04:28 PM
mtrain
Nov 24, 2011 09:25 AM
HondaGus
Jun 6, 2004 07:33 AM
