Help! Please!
Old Jun 5, 2004 | 02:26 PM
HondaGus's Avatar
Default Help! Please! *UPDATE*
i have a 2002 Accord Coupe SE 4 cyl
these past few days i been having problems with my accord,
i been taking sharp turns as always and the car now (NEVER DID THIS BEFOR) it like cut off my power, then once its going stright again the power comes back
the only thing i have touch since this problem are my spark plugs, i dont think that could be it, anyone have an idea?
please help me out.
*UPDATE*
This Will Only Happen When i Take a Hard Right, Wont Happen When i take Hard Lefts!
Modified by HondaGus at 4:06 PM 6/6/2004
Old Jun 5, 2004 | 02:41 PM
.bagged's Avatar
Default Re: Help! Please! (HondaGus)
check all your plug wires
Old Jun 5, 2004 | 03:23 PM
SlammedAccord96's Avatar
Default Re: Help! Please! (bagged93accord)
Yea like he said check plug wires, make sure they are secure at both ends (plugs and distributor cap). Also make sure they aren't cracked or worn or anything. Did this start RIGHT after you did your plugs? Did you gap them properly? Good luck!
Old Jun 5, 2004 | 03:26 PM
HondaGus's Avatar
Default Re: Help! Please! (SpeedFreak03)
yea i have checked the gap is okay, but i dont understand how taken a sharp turn can cut my power
ugh!
Old Jun 5, 2004 | 03:39 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaGus &raquo;</TD></TR><TR><TD CLASS="quote">yea i have checked the gap is okay, but i dont understand how taken a sharp turn can cut my power
ugh! </TD></TR></TABLE>
how bout the wires. if the wires are loose when you turn sharp they could loose connection.
Old Jun 5, 2004 | 03:41 PM
-RedneckDave-'s Avatar
Working
Hmm possibly could be a loose conection on the battery so check that.
Old Jun 5, 2004 | 03:45 PM
HondaGus's Avatar
Default Re: Help! Please! (-RedneckDave-)
When i say power i mean Motor Power, like the engine power gets cut then come back on,
the motor holds back, then when i go stright it gives me all the power back meanning HORSE POWER
Old Jun 5, 2004 | 03:47 PM
Working
Quit posting and check the stuff we said to check and then see if those are the problems.
.bagged's Avatar
fuel related??
Old Jun 5, 2004 | 03:49 PM
Working
Maybe fuel pump is going bad.
Old Jun 5, 2004 | 06:33 PM
HondaGus's Avatar
i checked everything you guys told me. the car will only act like that when it get warm,
fuel pump hmmmmmmm im gonna try with a full tank of gas
Old Jun 5, 2004 | 08:56 PM
HondaGus's Avatar
tomorrow ill be Changing my Spark Plugs AGAIN to see if that is the problem, im gonna be putting NGK R i hope this is the problem
Old Jun 6, 2004 | 07:33 AM
HondaGus's Avatar
BUMP
vtec_breh
Feb 27, 2011 06:30 PM
smoovekriminal
Aug 17, 2007 09:55 PM
murray195
Jun 10, 2007 12:57 PM
bighedstev
Apr 7, 2007 02:23 PM
black cx
18
Nov 28, 2004 01:05 PM
