Chadil Itb's
Old Apr 13, 2007 | 03:57 AM
hu's Avatar
hu
Default Chadil Itb's
I have been warned by several members here against using TWM itb's for my 96 Prelude.
I contacted Jenvey. They do not carry anything for the H22. Jenvey recommended, Chadil. They make itb's for the H22.
Have you heard of them? Opinions please...
http://www.chadil.be/
Old Apr 13, 2007 | 04:07 AM
hu's Avatar
hu
Default Re: Chadil Itb's (hu)
Jenvey told me that if I can get this manifold (bottom left):
Jenvey can supply some TB throttle bodies to fit.
Old Apr 13, 2007 | 04:35 AM
mgags7's Avatar
whats the price on that manifold??
Why is TWM so bad? just price?
Old Apr 13, 2007 | 04:45 AM
azrakain's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Why is TWM so bad? just price?</TD></TR></TABLE>
I don't own them, so this isn't first hand experience, but I always read about people having problems with the throttle sticking and issues with the vacuum system.
Old Apr 13, 2007 | 04:55 AM
Speedra500's Avatar
Default Re: (azrakain)
thats a pretty cool, that little adapter manifold. If someone made an adapter to make like 954RR throttle bodies bolt up.....they would probably be a rich man, very cool
Old Apr 13, 2007 | 05:00 AM
D-Rob's Avatar
Default Re: (Speedra500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azrakain &raquo;</TD></TR><TR><TD CLASS="quote">
I don't own them, so this isn't first hand experience, but I always read about people having problems with the throttle sticking and issues with the vacuum system.</TD></TR></TABLE>
From personal experience, I know the throttles like to stick open. An easy fix is to add a third return spring going the opposite direction at the driver's side strut tower.
And the vacuum system isn't the greatest, you have to drill and tap each runner and run to a vacuum log in order to get a somewhat constant MAP reading, like so:
- Derek
Old Apr 13, 2007 | 06:08 AM
hu's Avatar
hu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">whats the price on that manifold??
I was shocked by some of the PM's I got about TWM's. ****...even somebody who sells them doesn't recommend them (not on this forum)!
Basically, throttle sticking issues and vacuum issues.
Old Apr 13, 2007 | 07:15 AM
alterdcreations's Avatar
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">Jenvey told me that if I can get this manifold (bottom left):
hell ******* yeah...how much for them and what is the turnaround time?
also how much are the jenvy tb's and velocity stacks?
they also make their own tb"s also...might be cheaper
site looks good but currency is in euros
Modified by alterdcreations at 10:16 AM 4/13/2007
Old Apr 13, 2007 | 10:36 AM
hu's Avatar
hu
^ I sent Chadil an email and am waiting for a reply.
The only reason I am considering this is becasue Simon at Jenvey strongly recommended Chadil.
Old Apr 13, 2007 | 02:53 PM
Rosko's Avatar
Default Re: (hu)
interesting, maybe we could get a group buy on those flanges? I'd be up for at least one.
Old Apr 13, 2007 | 03:34 PM
Hardt's Avatar
Default Re: (Rosko)
Those manifolds are for DCOE TB's or carbs. They are also made to allow a maximum ID of 48mm.
Not worth messing with
Old Apr 15, 2007 | 02:01 AM
Rosko's Avatar
Default Re: (Hardt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardt &raquo;</TD></TR><TR><TD CLASS="quote">Those manifolds are for DCOE TB's or carbs. They are also made to allow a maximum ID of 48mm.
Not worth messing with</TD></TR></TABLE>
So what? No reason you can't port it out right? It wouldn't be that hard to design your throttle body around their bolt pattern or even make an adapter for an existing one. Its alot of work to machine a flange like that and if it could be had for a few hundred even, it would be well worth it. (to me at least)
Old Apr 15, 2007 | 02:37 AM
salman's Avatar
looks like a good idea,
will allso reduce the intake temps.
Old Apr 15, 2007 | 03:57 AM
Default Re: (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">
So what? No reason you can't port it out right? It wouldn't be that hard to design your throttle body around their bolt pattern or even make an adapter for an existing one. Its alot of work to machine a flange like that and if it could be had for a few hundred even, it would be well worth it. (to me at least)</TD></TR></TABLE>
i thought the same exact thing.
Old Apr 15, 2007 | 09:46 AM
machine4321's Avatar
in for more info
Old Apr 15, 2007 | 11:18 AM
DonF's Avatar
Default Re: (machine4321)
Under accessory's on the Jenvey site it show's adaptors for Weber type to SF type TB's . Just ask Simon, he can sort out what ever you need.
Old Apr 15, 2007 | 03:28 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">in for more info
x2
dglassmyer
Dec 10, 2012 10:02 PM
McLude2nR
Nov 22, 2006 08:13 AM
K-Spec
Jun 2, 2006 02:01 PM
ebp 99 si
Jan 30, 2004 11:10 AM
lilbill3554
Oct 29, 2003 08:28 AM
