z6 swap problems
Old Apr 13, 2007 | 01:19 AM
khmerkid's Avatar
Default z6 swap problems
i have a 92 civic cx with a z6 swap in it. it bogs down from 3000 and under, after that it will pull pretty strong. in order for it to run the dizzy has to be retarded....even then it still bogs. as it goes closer to advancing it sputters/bogs even worse. i've checked the belt timing and it seems to be on fine.. i've had it checked by two other ppl as well to confirm it. to add to the problem the plugs foul out with fuel flooding them. the motor is stock.
Old Apr 13, 2007 | 09:58 PM
khmerkid's Avatar
changed the plugs and after driving it for 30 mins it back to being fouled out. any help would be appreciated.
Old Apr 13, 2007 | 10:01 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Re: (khmerkid)
maybe it's running too rich? Check the air/fuel adjustment, the only think i can think of is a faulty distributor or ECU. It would be good if you knew someone you could swap those parts and try it out. That's all i can think of, i hope you find the problem man goodluck
Old Apr 13, 2007 | 10:20 PM
khmerkid's Avatar
i'm going to try those tomorrow, thanks
Old Apr 13, 2007 | 11:45 PM
JDM_Frijoles's Avatar
It could also be a vacuum leak, IACV, TPS, MAP, or:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rayz_Si &raquo;</TD></TR><TR><TD CLASS="quote">maybe it's running too rich? Check the air/fuel adjustment, the only think i can think of is a faulty distributor or ECU. It would be good if you knew someone you could swap those parts and try it out. That's all i can think of, i hope you find the problem man goodluck </TD></TR></TABLE>
Old Apr 14, 2007 | 10:35 AM
khmerkid's Avatar
bought a new dizzy helped alot, at first didnt bog, but starting to do it again. the spark plugs are burnin normal now. i have the dizzy at the center as well too. have any ideas why it would bog? i also bought another set of fresh plugs.
Old Apr 14, 2007 | 01:37 PM
khmerkid's Avatar
the bog got a little worse, the plugs are back to foul out again, but its still drivable. it now idles up and down from 2000 to 500. if it do decides to stay at a certain idle it would be around 2000. i'm stumped does anyone have any more suggestions
Old Apr 14, 2007 | 10:14 PM
khmerkid's Avatar
the only thing i haven't replaced yet are the wires, but i doubt that would really foul out my plugs and cause boggin..
Civstang
Sep 11, 2011 07:15 AM
90crxdriver
Apr 11, 2008 11:27 AM
SYTFU Tommy.
Apr 25, 2007 11:21 AM
1990hf
Jul 29, 2005 03:40 AM
JCR13
Mar 11, 2005 07:45 PM
