cable tranny/ hydro tranny
Old Apr 12, 2007 | 09:11 PM
grump's Avatar
Default cable tranny/ hydro tranny
i have a 94 ls and my tranny is goin out, i found a cable tranny for 75 bucks.... now,
can the cable tranny be converted to hydro... if not will the guts of the cable tranny fit into the hydro... or what of the two will interchange.... im thinking its just syncros, if so will they fit.... any info is greatly apppreciated...
Old Apr 12, 2007 | 10:50 PM
unknown0001's Avatar
Default Re: cable tranny/ hydro tranny (grump)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grump &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 ls and my tranny is goin out, i found a cable tranny for 75 bucks.... now,
can the cable tranny be converted to hydro... if not will the guts of the cable tranny fit into the hydro... or what of the two will interchange.... im thinking its just syncros, if so will they fit.... any info is greatly apppreciated...</TD></TR></TABLE>
If you pickup the cable transmission, you can buy the cable-to-hydro kit and use it to install the transmission and get it working fine
Old Apr 13, 2007 | 06:12 AM
brian L.'s Avatar
Default Re: cable tranny/ hydro tranny (Mr.RHTuner)
stay hydro bro i like cable but you don't want to downgrate like that
Old Apr 13, 2007 | 11:05 AM
Wraith_G2IC's Avatar
Default Re: cable tranny/ hydro tranny (DA69OG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA69OG &raquo;</TD></TR><TR><TD CLASS="quote">stay hydro bro i like cable but you don't want to downgrate like that</TD></TR></TABLE>
"Downgrate"????? I think you meant "downgrade", and it is hardly a downgrade. There are tons of reasons to go with one over the other depending on setup. Honda made the choice to go to hydro operated clutches to refine the "feel" of the clutch to appeal to the pansy *** consumers that can't handle the harsh feel that a cable clutch "can" give if you don't know how to drive it. There is no mechanical advatage of a hydro clutch over a cable clutch.
grump - The trans will bolt right up no problem. Where you may have a problem is if it is from a 90-91 Integra. The trans that came in the 90-91 had a smaller shaft with a different spline count than the 92-01 trans. All clutch disks and PP are interchangeable between a 92-01 trans, but not the 90-91. So if you were planning on re-using you clutch you wouldn't be able to. Look to see if the trans code is a YS1. ALL 92-93 Integras with the cable clutch have a YS1 trans.
Also, yes you can swap all the internals from a 94-01 trans into a 92-93 trans case. Now I don't know if you can just swap individual parts, but the chances are the trans you are looking at will have a grind anyway, so it is a toss up.
Old Apr 13, 2007 | 11:14 AM
super jdm yo's Avatar
Default Re: cable tranny/ hydro tranny (Wraith_G2IC)
^ couldn't have said it any better
that's the main reason i switched mine out, and got the ys1... and the fact that it was going out.
Old Apr 13, 2007 | 10:09 PM
grump's Avatar
ok so if it is just the syncros... anyone know how much those are???
lakai_19
Oct 3, 2007 05:28 PM
Walterronny
May 27, 2006 04:12 PM
jdmCivic925
Sep 23, 2003 10:02 PM
