Bondo Question
Old Apr 12, 2007 | 09:07 PM
hmtcrxsir's Avatar
Default Bondo Question
I just bought a Denji Projectors for the 92-95 Civic similar to the one shown below. I do not like the third small city light in the corner of the projectors. I want to cover it up and spray the housing black. I was thinking Bondo to cover the hole up but Im afraid that the bondo might crack due to the heat and movement. Anyone suggestion any other material to cover up the third hole without worrying that it might crack overtime.
Old Apr 12, 2007 | 09:12 PM
Markland Photo's Avatar
i think if the whole city light housing part was completely removed and it was bondo'd up nice and tight it should be aight, plus it would only be exposed to heat when you have your high beams on most likely, your low beams are a good 4 inches away from the spot
ninja edit: ps, im no bondo expert, so dont depend on that
Old Apr 12, 2007 | 09:16 PM
SneezinCD5's Avatar
Default Re: Bondo Question (hmtcrxsir)
Fiberglass if anything. Bondo is not made to fill holes. Fiber strand/kitty hair is for holes. Bondo is kind of like icing on the cake. Just a thin layer to smooth and level everything out.
Old Apr 12, 2007 | 09:17 PM
hmtcrxsir's Avatar
Default Re: (bulletspastsunset)
so how do i add fiberglass to a hole that is 1.5 inch deep? KittyHair will not crack regardless of depth? Is it reinforced?
i used bondo in the past but not as deep as the hole in the housing.
Modified by hmtcrxsir at 10:36 PM 4/12/2007
Old Apr 12, 2007 | 10:28 PM
oOoEG6oOo's Avatar
Default Re: (hmtcrxsir)
how bout jbweld?
Old Apr 12, 2007 | 10:49 PM
hmtcrxsir's Avatar
Default Re: (oOoEG6oOo)
lol
Old Apr 12, 2007 | 10:51 PM
hoodrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oOoEG6oOo &raquo;</TD></TR><TR><TD CLASS="quote">how bout jbweld?</TD></TR></TABLE>
Naw get some premium 1st grade elmers
seriously though i would go with fiberglass, or some sort of epoxy resin type mixture
Old Apr 12, 2007 | 11:15 PM
hmtcrxsir's Avatar
Default Re: (hoodrider)
you think if i just fill the hole with fiberglass and bondo on top to make it smooth. you think it will crack overtime?
Old Apr 13, 2007 | 02:47 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">you think if i just fill the hole with fiberglass and bondo on top to make it smooth. you think it will crack overtime?</TD></TR></TABLE>
depends how well is the prep work, if you lay one layer of fiberglass and a can of bondo why not? the bondo will shrink over time, if you pay alot of those then it will make the changes more dramatic.
you need to use bondo to fill it up ulitmately, the base you can do fiber glass or just weld plastic(abs, etc) for support.
Old Apr 13, 2007 | 10:42 AM
hmtcrxsir's Avatar
Default Re: (iam7head)
how about fill the hole with epoxy glue and then use bondo to smooth it out? Will that hold?
Old Apr 13, 2007 | 10:56 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Wouldn't it be nice if we had a paint/body forum to ask questions like this? The professionals would hang out there and give sound advise.
https://honda-tech.com/zerothread/1951877
Old Apr 13, 2007 | 10:57 AM
hmtcrxsir's Avatar
Default Re: Bondo Question (-NA-aLL-thE-wAy-)
but then again who actually do bodyworks by themselves? not many of us
Old Apr 13, 2007 | 11:31 AM
John M's Avatar
you posted this in almost every sectionSTOP and stick to one section
Old Apr 13, 2007 | 12:49 PM
GSR-T-'s Avatar
id just leave it like it is
Old Apr 13, 2007 | 08:05 PM
SneezinCD5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">but then again who actually do bodyworks by themselves? not many of us
You would be suprised how many people try to do it themselves. I do all of my own and it is very rewarding when it is all said and done
Old Apr 13, 2007 | 08:08 PM
hmtcrxsir's Avatar
Default Re: Bondo Question (SneezinCD5)
but you need a place to do it like a garage. its nearly impossible to paint your car without a good place that has much ventilation
Old Apr 14, 2007 | 12:12 AM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">but you need a place to do it like a garage. its nearly impossible to paint your car without a good place that has much ventilation</TD></TR></TABLE>
true but then again not true btw you dont want to use filler on top of plastic that **** will fall right off in no time.
Old Apr 14, 2007 | 12:15 AM
i do
Old Apr 14, 2007 | 12:25 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">how about fill the hole with epoxy glue and then use bondo to smooth it out? Will that hold?</TD></TR></TABLE>
oh no..don't even try
Old Apr 14, 2007 | 12:40 AM
hmtcrxsir's Avatar
why not?
Old Apr 14, 2007 | 05:02 PM
xDicktonesx's Avatar
get a boat repair kit and fiberglass it. sand until smooth. paint.
gbarbur
Honda Civic (2001 - 2005)
Sep 2, 2012 10:23 AM
hmtcrxsir
11
Apr 13, 2007 04:17 PM
hmtcrxsir
16
Apr 13, 2007 11:11 AM
hmtcrxsir
Apr 13, 2007 01:07 AM
hmtcrxsir
Apr 12, 2007 11:32 PM
