fan question
Old Apr 12, 2007 | 04:05 PM
eliasromero's Avatar
Default fan question
89 civic hatch
i want to connect the fan directly but i dont know which cable to ground.
does anyone know which cable to connect so the fans will turn on when i start the car?
Old Apr 12, 2007 | 07:01 PM
Sam92Teg's Avatar
Default Re: fan question (eliasromero)
You could disconnect the connector from your temp switch and run a jumper wire in the connector and tape it up real good. It should run the fan whenever the ignition switch is turned on.
Old Apr 13, 2007 | 12:56 PM
WHICH CABLE?
Modified by eliasromero at 6:49 PM 4/14/2007
j4s0n1337
52
May 13, 2011 09:55 PM
julioboostamante
11
Jul 23, 2010 10:28 AM
jdragon1974
May 20, 2010 08:24 AM
jry2598
Aug 28, 2006 10:19 AM
blaster834
Sep 16, 2004 11:52 AM
