tire size on a 17 x 7.5 " wheel
tirerack says they reccomend 225 45 r17 for my car with a 17x7.5" wheel.... 04 base rsx... now normally id go with it but im planning for a drop in the future. almost 2 in. with eibach sportline springs. so is it possible to put on a 215 45 r17 on the wheel w/ it not looking stretched?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_drk »</TD></TR><TR><TD CLASS="quote">225 would work fine as they said, but personally i would also go with 215. It wouldnt look stretched at all.</TD></TR></TABLE>
You can usually tell whether tires look stretched by checking the specs for the range of rim widths approved for the tires. As long as the wheel width is in the middle of the range, the tires should look fine. They tend to look stretched when the wheel width is at the maximum of the range for that size tire.
Most 215/45-17 tires are approved for rims 7.0-8.0 inches wide, and 225/45-17 for 7.0-8.5. In either case, the tires should look fine on a 17x7.5 wheel.
Costco
Apr 9, 2011 10:26 PM
bb6h22a
18
Jul 28, 2005 01:22 PM
