Question about IM and TB .. DIY Topic .. i have searched!
Old Apr 12, 2007 | 12:52 PM
Civic98KH's Avatar
Default Question about IM and TB .. DIY Topic .. i have searched!
i have searched to see there are no DIY's for port and polish intake manifold and maybe throttle body .. can any1 help me with port and polish for my intake manifold at least...
thanks
kyle
Old Apr 12, 2007 | 01:16 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Question about IM and TB .. DIY Topic .. i have searched! (Civic98KH)
Get a set of grinding stones, put some paint on your gasket or trace around it, grind away everything to the border of the gasket marks. Pretty simple stuff. Don't polish anything unless you know exactly how you want the air to mix with the fuel
Old Apr 12, 2007 | 06:54 PM
Civic98KH's Avatar
do you think it is really worth the trouble of grinding it?
Old Apr 12, 2007 | 09:44 PM
CivicSpoon's Avatar
Default Re: (Civic98KH)
If you're making, or plan to make enough power to need a bigger throttle body and IM opening. On a stock engine with or without basic bolt-ons, then no it will absolutely not be worth it.
Old Apr 12, 2007 | 10:30 PM
EJAYATE's Avatar
I Deliver
I had a ported intake manifold. I didn't really effect much and just made my intake louder if it wasn't already loud enough. I put the stock one back on.
Old Apr 12, 2007 | 10:56 PM
Boostedb20EH2's Avatar
Default Re: (B2CivMan)
It doesnt effect much because you didnt do it right and you probably lost power. If you cant flow test it properly then dont do it yourself. Take it to a shop
Old Apr 13, 2007 | 05:33 AM
Civic98KH's Avatar
okay thanks guys! .. i was just seeing what i could do while it is off that car .. and i know im going to need a new intake manifold gasket .. will i need to get new injector seals?
Old Apr 13, 2007 | 07:47 AM
97Ej6mike's Avatar
As Long as the Injector seals arent dried, cracked, and flaking, and still have their rubbery flex to them, they should be OK.
Old Apr 13, 2007 | 07:55 AM
Marauder's Avatar
Default Re: (97Ej6mike)
You are better off getting a performance intake manifold, like the Edelbrock PerformerX. The whole runner has a larger cross section and it has a shorter runner. Things you can't change with a port/polish.
I would think, at most you'd see 2hp gain from a good polish job, and you'd be lucky to get more than that with a port job, unless you motor was really built.
Old Apr 13, 2007 | 08:43 AM
Civic98KH's Avatar
well im getting the skunk2 intake manifold and a b16 throttle body for 150 delivered .. i think its gonna be nice for my car lol
Turbo_y8
Jan 10, 2006 09:00 AM
99RedSi
May 21, 2005 08:44 PM
Integacivic
Jul 31, 2004 01:59 PM
96SR-V
Feb 16, 2003 09:32 AM
zilverz
Jun 23, 2002 12:58 PM
