Honda S2000 Honda S2000
Luis's 2jz S2000
Old Apr 12, 2007 | 10:33 AM
prr1's Avatar
Default Luis's 2jz S2000
I will let the pictures speak for them self.
<FONT SIZE="7">Some Pics of the Motor</FONT>
<FONT SIZE="7">Now for the interior shots</FONT>
Modified by prr1 at 1:29 PM 4/12/2007
Old Apr 12, 2007 | 11:02 AM
BondoBuilder's Avatar
Default Re: Luis's 2jz S2000 (prr1)
Did you keep the stock rear end? How many pounds of boost are you running? How many hours did you have in the swap? How much did it cost...just curious?
Old Apr 12, 2007 | 11:42 AM
SlvrStone 2001's Avatar
Default Re: Luis's 2jz S2000 (BondoBuilder)
that's a 'sleeper'
Old Apr 12, 2007 | 11:51 AM
TurboIntegra's Avatar
Default Re: Luis's 2jz S2000 (SlvrStone 2001)
Looks great! You need to get rid of that dinky *** intake though. Why didn't you use a true 4" intake like the turbo was designed for?
Old Apr 12, 2007 | 12:20 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BondoBuilder &raquo;</TD></TR><TR><TD CLASS="quote">Did you keep the stock rear end? How many pounds of boost are you running? How many hours did you have in the swap? How much did it cost...just curious? </TD></TR></TABLE>
x2
And does it still handle while going any other direction than straight ahead?
Old Apr 12, 2007 | 12:28 PM
sixsixsix's Avatar
OneWayHighway
Default Re: Luis's 2jz S2000 (SuzukaBlueAP2)
i like the front rake!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 12, 2007 | 12:47 PM
fred92htch's Avatar
Default Re: Luis's 2jz S2000 (sixsixsix)
Good God
Old Apr 12, 2007 | 03:31 PM
Phil DeVtec's Avatar
Default Re: Luis's 2jz S2000 (fred92htch)
Now that is a S2K!
Old Apr 12, 2007 | 04:14 PM
93egallmotor's Avatar
wow, that probably rips...but what is up with that shifter. iknow its kinda not that important but it looks like poo
Old Apr 12, 2007 | 04:32 PM
m R g S r's Avatar
Default Re: (singlecamy8)
the shifter sits back farther on the 2jz tranny....so it cant be in the stock location. . .
Old Apr 12, 2007 | 05:40 PM
b e b's Avatar
Default Re: (m R g S r)
Wow that is badass!!
Old Apr 12, 2007 | 06:11 PM
Francesco's Avatar
Old Apr 12, 2007 | 06:12 PM
wildoutwhitegsr's Avatar
How long have you been working on this?
Will you be taking it to the dyno? Did you do a dyno run before you did this?
-PrincessS2K posting
Old Apr 12, 2007 | 07:52 PM
Honda-Hooligan's Avatar
Default Re: (wildoutwhitegsr)
need some answers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 12, 2007 | 08:40 PM
ohhhdang's Avatar
Default Re: (Honda-Hooligan)
wow, you can fit a baby in that turbo!
Old Apr 12, 2007 | 11:34 PM
hoodrider's Avatar
Default Re: (ohhhdang)
completely against what the S2k is ment for, but i guess if you have the money thats your thing
Old Apr 13, 2007 | 04:51 AM
93civic_sedan's Avatar
Seems like the shifter is way far back and might hit the cup holder. Also that intake does seem like it might kill the flow. Whats the wiring like?
Old Apr 13, 2007 | 06:02 AM
prr1's Avatar
Default Re: (93civic_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civic_sedan &raquo;</TD></TR><TR><TD CLASS="quote">Whats the wiring like?</TD></TR></TABLE>
Here is a pic of the wiring that is behind the kick panel.
Old Apr 15, 2007 | 03:15 PM
g2b2's Avatar
a friend of mine saw it in person and said that the front cross member was removed and not replaced. Pretty sick idea though
Old Apr 15, 2007 | 04:17 PM
Shadowz7429's Avatar
damn!
Old Apr 15, 2007 | 07:12 PM
mrivera's Avatar
2jz
s2k
2jz + s2k = ..eh.. no thanks.
Old Apr 15, 2007 | 07:27 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (mrivera)
big engine + little car =
Old Apr 16, 2007 | 04:56 AM
prr1's Avatar
Default Re: (g2b2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2b2 &raquo;</TD></TR><TR><TD CLASS="quote">a friend of mine saw it in person and said that the front cross member was removed and not replaced. Pretty sick idea though</TD></TR></TABLE>
There is a lot of people claiming to have seen this car in person. Most of them haven't. The car has always had a car brace forward of the motor. You can see it below the A/C line. 1/4in thick tubular steel.
Old Apr 16, 2007 | 08:52 AM
Mr. Nop from C*H's Avatar
I'M FROM DAT PLACE CALLED ^
Default Re: (rochesterricer)
holy ****! how hard was that to put in there?
Old Apr 16, 2007 | 09:20 AM
Startrek's Avatar
This is becoming like a B18 swap into a civic
