Optimal Running Water Temp (GSR)
Old Apr 12, 2007 | 01:27 AM
Astig's Avatar
Default Optimal Running Water Temp (GSR)
I just installed an autometer water temp gauge (mechanical), tapped into the upper radiator hose by way of autometer #2282. I went driving around tonight, cool weather out, and noticed my running temperatures ranged from about 195-205. After the drive, I came home and let it idle. Temps creeped up slowly to 220, then the fan kicked on and it dropped back to 205.
Not sure what would be considered normal here... thanks!
Old Apr 12, 2007 | 01:06 PM
Astig's Avatar
Default Re: Optimal Running Water Temp (Astig)
Bump
Old Apr 12, 2007 | 01:16 PM
trickeng's Avatar
it depends on where your picking up the temp from. the water will be the hottest as it exits the head on its way to the radiator.
Old Apr 12, 2007 | 01:20 PM
Astig's Avatar
Default Re: Optimal Running Water Temp (trickeng)
Upper radiator hose
Old Apr 13, 2007 | 05:34 AM
trickeng's Avatar
that is the hottest spot in the system and autometer guages are not the most accurate guages, so most likely its fine.
keep in mind you thermostat is at the back of the motor where it opens around 180degrees. try installing your guage on the engine side of the theromstat of if you have engine management, check the oem readings.
Old Apr 13, 2007 | 11:27 AM
Astig's Avatar
Wouldn't you want to get a reading nearest to the head in case of a blown headgasket? I'd want to see the quickest response from the gauge so I can shut everything down in time.
Old Apr 16, 2007 | 10:32 AM
trickeng's Avatar
the responce time of a water temp guage is super latent anyway. they are not like exposed element fast responding thermocouples (i.e. EGT's). it takes many seconds for the sensor to catch-up with the actual temp rise of the liquid.
iBrandon
May 20, 2006 03:01 AM
project civic
Mar 16, 2006 09:46 AM
budget
Jun 5, 2005 11:03 PM
turbohf
Jan 27, 2003 10:06 AM
Albino Dragon
Apr 18, 2002 10:15 PM
