civic type-r pistons in ls vtec
Old Apr 11, 2007 | 08:51 PM
disgsrguy's Avatar
Default civic type-r pistons in ls vtec
i have a ls vtec and a brand new set of civic type-r pistons laying around.the lsvtec is a b18a1+b16 head. pretty much stock but the block has b16 pistons right now. is putting the ctr pistons into the ls/vtec a good idea?
Old Apr 12, 2007 | 04:31 AM
mac_24_seven's Avatar
Default Re: civic type-r pistons in ls vtec (disgsrguy)
Your compression would be insane..... Not great for a DD.
Old Apr 12, 2007 | 10:55 AM
Integra_drk's Avatar
youd be approaching like 13.5:1 area, thatd be crazy unless you run some real high octane ****.
Modified by Integra_drk at 6:41 PM 4/12/2007
Old Apr 12, 2007 | 11:07 AM
disgsrguy's Avatar
this engine is not going to be for DD. it's my play motor. i already have a dd, it's a gsr that i'm using and also it has very low miles still. would this be a good idea to do? will it cost me alot of money to have it put in and tuned?
Old Apr 12, 2007 | 11:17 AM
dohcMONSTER's Avatar
Default Re: (disgsrguy)
i ran CTR's with a GSR head and 91 and it ran fine with no pinging or detonation. But i had Massive cams and lift to compensate, but it is possible to do and make some awesome power
Old Apr 12, 2007 | 12:56 PM
disgsrguy's Avatar
someone from teamintegra said there is a possibility that it might not fit. he also sed i had to clayed and modified to fit "just" then i can squeeze them in. did u have to do all that?
the head dose not have any upgrades at all at the moment, but wut cams are u running?
Old Apr 12, 2007 | 01:43 PM
FullRaceHonda's Avatar
yeah that compression ratios not going to do you any good without atleast some pretty aggresive cams and valvetrain
if your going to do that much work you should just bore it out to 82mm with some forged pistons and rods and then you can have some real fun
Old Apr 12, 2007 | 03:02 PM
Default Re: (FullRaceHonda)
i ran 82mm CTR's with Blox competitions HSL's. which are equivilant to skunk2 stage 3's with slightly bigger primaries
Old Apr 12, 2007 | 04:46 PM
Tomdata's Avatar
do it. you won't have any problems. just plan on having to add some race gas to each tank. retard the timing all the way and you should be able to get away with pump gas (but that defeats the purpose of raising the compression). I have used this setup many many times with no problems.
Old Apr 12, 2007 | 04:49 PM
Default Re: civic type-r pistons in ls vtec (Tomdata)
if you have a qualified tuner in your area, e85 would be great for this setup.
Old Apr 12, 2007 | 07:11 PM
disgsrguy's Avatar
i want to do it, but others are saying dont do it. if i dont do it then i bought these pistons for nothing. never gotton a car tuned before yet, but alot of tuners in my area for imports. if i do plan to sell pistons how much can i make from them? standard bore w/ rings, barrings and wrist pins.
Old Apr 16, 2007 | 06:48 PM
disgsrguy's Avatar
if i were to put the ctr pistons in, will the stock rods work? or do i have to get new/different ones?
Old Apr 16, 2007 | 08:29 PM
doood's Avatar
been there done that
you already have enough compression to make use of a whole bunch of cams. what cams are you considering that you need close to 13:1?
Old Apr 17, 2007 | 01:53 AM
tomlinson619's Avatar
Default Re: (doood)
not worth the upgrade. ur comp is already high
Old Apr 17, 2007 | 08:34 AM
CompleteSR06's Avatar
Default Re: (doood)
hey i have a ls/vtec stage 2 cams, duel springs & tit retainers when i had it built highest compression i could get was 12.1:1 itr stock 10.98:1 i use a p73 9000rpm
runs fine. i also have intake manifold upgrade also throttle body 68mm lots of power make sure to get a lsd trans you lose displacement if you switch from ls to itr rods
but good luck
Old Apr 17, 2007 | 08:53 AM
Default Re: (skunk2 VTEC)
you can also use a b20 knife edge the crank put a block gurttle on it shot peen the rods change pistons to up compression. take your b16/gsr head with spring upgrade do a intake/exhaust port you now have a itr head bore it to 84mm to fit block
N/A VTEC POWER REV HIGH 9000RPM
Old Apr 17, 2007 | 08:58 AM
MajorPayne's Avatar
Default Re: (CompleteSR06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompleteSR06 &raquo;</TD></TR><TR><TD CLASS="quote">you can also use a b20 knife edge the crank put a block gurttle on it shot peen the rods change pistons to up compression. take your b16/gsr head with spring upgrade do a intake/exhaust port you now have a itr head bore it to 84mm to fit block
N/A VTEC POWER REV HIGH 9000RPM</TD></TR></TABLE>
what the hell did you just say?
Old Apr 24, 2007 | 08:20 PM
disgsrguy's Avatar
well i've decided to just sell the motor and concentrate on my gsr. if there is anyone who is interested then let me know.....might just throw in the ctr pistons for a lil xtra. b18c1mien@yahoo.com
Old Apr 24, 2007 | 09:55 PM
crazytalk's Avatar
i actually has the ctr in my ls block and am considering to go vtec witha b16 but people tell me to go with gsr head i dont know if i should tho either my compression with the ctr pistons is 12:1
botlebruiser
Mar 14, 2006 05:04 PM
stockb16hatch
30
Feb 21, 2006 12:42 PM
tegasaurus
Jan 28, 2004 12:40 PM
flyrice
Nov 1, 2003 02:19 PM
chuckd05
Mar 26, 2003 08:15 AM
